Old 06-22-2007, 10:23 PM   #1
truknut
truknut's Avatar
Gas Needle Flops
I was wondering if everyones gas needle flops back and forth on the 67-72 trucks? I have the tank behind the seat. I'm wanting to put a blazer tank or something else, I was wondering does the blazer tank do the same thing with the factory gauges?
1990 Chevy Silverado (My DD)
1978 Chevy Bonanza LWB (My LWB to SWB 1 day project)
2015 Hyundai Sonata (Wife's DD)
truknut is offline   Reply With Quote
Old 06-22-2007, 10:32 PM   #2
nplocoman
never finish start another
nplocoman's Avatar
Re: Gas Needle Flops
Possible, a semi flooded float? Or ground problems. Time for a little trouble shooting!
nplocoman is offline   Reply With Quote
Old 06-23-2007, 12:41 AM   #3
Chevelle454
Chevelle454's Avatar
If the wire going to the tank is grounding out, the gauge will go to empty. I had my wire pinched in the door once and didn't know why the gauge was saying empty...it was grounding on the door sill.
1972 C10
1972 C20
Chevelle454 is offline   Reply With Quote
Old 06-23-2007, 01:54 AM   #4
1970shortbed
Active Member
every old car/truck i have does this as the float moves up and down when you corner or hit bumps stuff like that makes the float move
1970shortbed is offline   Reply With Quote
Old 06-23-2007, 10:31 PM   #5
truknut
truknut's Avatar
1970shortbed<<<<<<<<< That's what I was thinking. I was wondering if when you change to the blazer tank does it still bounce back and forth when turning?
Old 06-23-2007, 10:52 PM   #6
1970shortbed
Active Member
i would assume it will seeing it has the same type of float setup
