stock fuel tank liner job & filter and sending unit
How do I remove the sending unit and pickup filter from a stock tank on a 69 truck? Is there anything to service inside???
The tank is out of truck and I was thinking about a liner job on the tank if it looks at all corroded. the local radiator shops will pickle it out , but they will not do a liner job in case something comes loose. I did an old Jeep tank years ago with 2 motorcycle tank kits,(10 gallon tank) and it has lasted now 20 years without fail. Does anyone have personal experience with this >?????? Thanks |
Re: stock fuel tank liner job & filter and sending unit
theres a metal ring with tabs on the sender just take a screwdriver and hammer and rotate counter clockwise to remove sender under the sender theres oring that should b replaced
i've sealed and had a few sealed with no bad results and lasted long
Thanks for the good info!
its all about the +6 inches
explain "pickle it out".
the rad shop dips it in the hot tank to clean and descale its usually done by a fat guy eatin a gerkin
the hot tank is a bad idea for a fuel tank. The guy who runs our rad shop at work showed me with an old tank we had when i asked him to do that.
We dropped it in there for 30 min, when it came out, there was still rust inside, but all the solder was gone, which made the filler neck fall off. Dunked it back in for another 30 min, and when it came out, there was still a little rust, but there were holes where some of the seriouse rust was. The way we do it is with a steam cleaner. The heat and pressure will blast the rust off, but leave the metal unharmed. And it does nothing to the solder. It may take 2 or 3 hrs with the wand in there, but the end result is better. |
I need this or something done to my tank. Not sure I want to hassle w/ a repop.
1969 C/10 swb, 350, powerglide (daily driver) 2005 CRV (wife's ride) |
![]() Join Date: Nov 2006
just find a good used one there out there. post a wanted add and it will show up most likely. this is a great bunch of guys and will help out all they can from my experience on this site.i bet billsbowtie on the board has one. pm him.
bob in tn.
I BELIEVE IN JOHN 3:16 |
Maybe I don't wanna line it!????
70knight
![]() Join Date: May 2007
If you are going clean the gas tank .eastwood have a kit for about 44.99 the kit come's with 7oz. metal wash ' 1 pint of fast etch ' 1 quart of gas tank sealer. it work very good . 70 knight www. eastwood. com
