Old 06-20-2007, 08:02 AM   #151
MEANGREEN70
MEANGREEN70's Avatar
Re: Xmas In March, Thanks To Porterbuilt.
Originally Posted by SCOTI View Post
Since most are using the 380's I would say the 480's would work just as well. Got that front clip in place yet?
No not yet, hoping by this wkend I'll will. Cant wait to see on the truck. I can get 2 480 comps for about $380.00.
MEANGREEN70 is offline   Reply With Quote
Old 06-21-2007, 12:49 PM   #152
blaznhot_23
blaznhot_23's Avatar
looking good..can't wait see when its all done!!!
blaznhot_23 is offline   Reply With Quote
Old 06-21-2007, 04:03 PM   #153
dan468
dan468's Avatar
Originally Posted by MEANGREEN70 View Post
I was thinging 2 480 viar, are they pretty good?
MeanGrean, how did you/do you plan to wire the two compressors together? I am using a viair relay/pressure switch but I'm not sure how I'm going to use it to hook up two compressors. Any suggestions?
68 C-10
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=414699
dan468 is offline   Reply With Quote
Old 06-22-2007, 04:19 PM   #154
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
[IMG]http://*****************/how_to/wire-diagrams/compressor.gif[/IMG]
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 06-23-2007, 09:24 AM   #155
MEANGREEN70
Scoti, got the front clip in place this wk. looks good
I'll be posting pics this wkend when I push the old girl out of the garage, so she can get some sun if it doesn't rain.
Old 06-23-2007, 09:32 AM   #156
MEANGREEN70
dan468, suicide doors sell a relay made for a 2 copm setup.
I'm going to be using one, and thwn I'm putting a pressure switch on each tank.
Hope this helps you, let me know if you need more info.
Old 06-23-2007, 11:31 AM   #157
SCOTI
SCOTI's Avatar
Let's get together....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-25-2007, 07:09 PM   #158
L0WRIDE
L0WRIDE's Avatar
Any progress pics MeanGrean ???
49 CHEVROLET 1/2 TON, 52 CHEVROLET SEDAN
62 HARDTOP NOVA
65 CHEVROLET BB LWB FLEETSIDE
90 CHEVROLET EXTRA CAB
CHEVY ONLY - NZ Chapter
http://67-72chevytrucks.com/vboard/s...d.php?t=137984
L0WRIDE is offline   Reply With Quote
Old 06-28-2007, 09:31 PM   #159
BigShoe24
True Addiction
BigShoe24's Avatar
I want one of the Porterbuilts crossmembers so bad. From what I understand it narrows the front and moves it forward? I was wondering what kind of offset you guys are running that have the Porterbuilt X member. I have a narrowed 9" out back and want to run wheels with a large outside lip. I already have Strong Arms and am running RE7's with CPP drop spindles. I was hoping that someone could give me the exact specs or any helpful info on the Porterbuilt X member. Thanks
BigShoe24 is offline   Reply With Quote
Old 06-28-2007, 10:01 PM   #160
PBFAB.COM
PBFAB.COM's Avatar
BigShoe24-
I run a 8.5" wheel with a 5.5" backspacing. The Dropmember will narrow the track-width one inch per side, and yes, it does move the axle center-line forward to center the wheels in the wheel-wells when deflated. If you have some more specific questions post em up on the Dropmember thread and I will be happy to answer them all.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 07-01-2007, 12:05 AM   #161
MEANGREEN70
SCOTI, lets try to get together sometime next wk?
Old 07-01-2007, 12:10 AM   #162
MEANGREEN70
I'll try to post pics this wkend of what I been working on, I'm trying to use the original fender well, instead of a trailer fender. It is taking a lot of guess work.
Old 07-01-2007, 12:13 AM   #163
MEANGREEN70
bigshoe, nice truck, yeah it needs a porter crossmember. you'll love it
Old 07-02-2007, 07:34 PM   #164
MEANGREEN70
A sneak preview of the truck with the new front end, haven't have a good day that I can push it out of the garage. To much rain
I'm also working with he original fender wells, trying to make then work so i don't have to use a trailer fender. Not that there anything wrong with.
Old 07-02-2007, 07:40 PM   #165
babyblueoval
babyblueoval's Avatar
It's lookn' awesome.
I can't wait to get started on my Blazer.
Jim
'71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E
'57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works
'87 BMW 325i - daily driver
babyblueoval is offline   Reply With Quote
Old 07-02-2007, 08:15 PM   #166
dan468
dan468's Avatar
Is your hood just resting on there or did you fab some to work with the new big wheels/tires?
Dan
68 C-10
Build thread
Old 07-02-2007, 11:05 PM   #167
MEANGREEN70
Dan
The hood is resting on the fenders inner lips where it suppose to go, the only thing I did was cut the fenders to clean the tires. I'm running 20 inch wheels.
Old 07-02-2007, 11:30 PM   #168
dan468
dan468's Avatar
what are you going to do for hood hinges?
68 C-10
Build thread
Old 07-02-2007, 11:48 PM   #169
blaznhot_23
hey meangreen could take another pic at a differnet angle of your inner fenders. i'm curious how you mounted in there so cleanly...thanks!!!
Old 07-03-2007, 12:41 AM   #170
L0WRIDE
L0WRIDE's Avatar
NICE!!!meangreen
62 HARDTOP NOVA
Old 07-03-2007, 01:19 AM   #171
BigShoe24
True Addiction
BigShoe24's Avatar
MEANGREEN70,
Your truck looks GREAT! I was wondering what you think of running 22's (probably will be 9.5" or 10" wide) with the porterbuilt. Is this a bad idea? I dont really care to lay frame, just want to get really low. Plan on purchasing a crossmember in the very new future. Just need to save a few more $$$. Thanks for any suggestions.
Shoe,
Old 07-03-2007, 08:18 AM   #172
MEANGREEN70
dan468, I'm going to use the hinges that sachse rod shop
makes,their down the street from me, so I seen the hinges in person and they are cool looking.They mount on the firewall. I'll try to get some pics of then, or you can go to thier wed site.
Old 07-03-2007, 08:20 AM   #173
MEANGREEN70
I'll try to get you some more pics of the fender wells today.
Old 07-03-2007, 08:33 AM   #174
MEANGREEN70
MEANGREEN70,
Shoe,
Bigshoe, I personally dont like anything over 20 inchs tall, before i got my,I looked and looked at my trucks and just didnt like that tall of a tire-wheel combo. The wheels that I'm running are 20s, (10" in the rear and 8.5 in the front).
they tuck just perfect under the fenders for me. But like I said this in just my personal opinion, I have seen some nice trucks with big wheels.
I dont thing you'll have any problems running then, I do know that it takes more trinning of the inside fenders. I hope this helps you some.
Old 07-05-2007, 05:26 PM   #175
BigShoe24
True Addiction
BigShoe24's Avatar
PORTERBUILT,
I was wondering how much more drop the crossmember provides? I believe I have saved up enough money to purchase the crossmember, rack & pinion, according to the prices in your website. Last, I was curious to know if you keep them in stock or build upon ordering. Thanks for the help, and any other information would be great.
