Old 06-25-2007, 08:35 AM   #1
babyJay
Arrived on a Pale Horse
babyJay's Avatar
4x4 frame conversion
Can I put a 72 SWB truck body on a 71 Blazer frame? I know it won't be easy, just wondering if things would "bolt up" or what. Wheel bases the same, etc? Thanks.
Jason
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 06-25-2007, 09:10 AM   #2
Mudder
Mudder's Avatar
Re: 4x4 frame conversion
Blazer frames are shorter and would have to be lengthened.
Mudder is offline   Reply With Quote
Old 06-25-2007, 11:32 AM   #3
babyJay
babyJay's Avatar
Thanks!
Jason
89 R3500 CC SRW
Old 06-25-2007, 12:03 PM   #4
OLDCHEV4X4
OLDCHEV4X4's Avatar
Or put the cab on and shorten the bed...a super short bed!
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 06-25-2007, 08:00 PM   #5
eedgell
It's the air up here
eedgell's Avatar
If you shorten the bed, it's only 4 or 5 inches.. isnt it? It would still look pretty cool, and not hard to do for a body guy.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 06-25-2007, 09:48 PM   #6
earl87gta
earl87gta's Avatar
do a serch on trazers and you will see a few truck cabs on blazer frames.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 06-26-2007, 01:36 AM   #7
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Here's a couple of Trazer shots...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 06-26-2007, 10:59 AM   #8
6T8
Active Member
It's more work than you think. I've done it. Cab mounts are different on rear. Need to put 2" body lift or cut out back of lower cab. They do ride nice though. Good luck.........Rick
6T8 is offline   Reply With Quote
Old 06-26-2007, 11:53 AM   #9
1lowdiesel
1lowdiesel's Avatar
looks a little goofy imo
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
1lowdiesel is offline   Reply With Quote
