Old 12-10-2002, 05:03 PM   #1
Zumo
Hot Rods For Life
Zumo's Avatar
Should I get a big sucking swooshing sound (vacuum) when I pull my gas cap off?
I noticed the "Gas Smell" post and I am having the same type of problems. Should I get a vented cap?
1968 C10 LWB ****SOLD***
Andy
Viva Los Bicicletas!
Los Muertos Custom Bicycles
Zumo is offline   Reply With Quote
Old 12-10-2002, 05:11 PM   #2
Dim
Tha Russian Canadian
Dim's Avatar
Yes you should.
I've seen tanks with so much pressure that as soon as you twists the cap, it gets shot at you. So i can't see how that much preasure can be good for the tank.
Dimitri
Lethbridge, Alberta
69 Chevy C10 - (Under Construction)
pos_8@hotmail.com
Dim is offline   Reply With Quote
Old 12-10-2002, 06:12 PM   #3
Southpa
Southpa's Avatar
I usually get back pressure on hot summer days. Been looking for a vented cap but they seem to be rare as hen's teeth in these parts. I'm using an aftermarket locking cap right now and I sometimes reach back and push in on the gasket to release excess gas fumes while driving.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 12-10-2002, 06:17 PM   #4
da-burb
"Ochre Ogre"
da-burb's Avatar
No you shouldn't. The gas caps for 71 and 72 were non-vented and 67-70 were vented. If your cap holds a vacuum or pressure, then the cap is not vented. Either it has become plugged, or it is a 71-72 cap.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 12-12-2002, 01:50 PM   #5
Andy4639
Old member
Andy4639's Avatar
Cool Venting
Getting that much pressure in the tank can cause other problems also. It can starve the carb in hot weather, stubbling when accelarting, and it could colaspe the gas tank in some cases, if you can't find the caps try routing a peice of fuel line some how to vent it.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
