Old 06-26-2007, 05:35 PM   #1
byrd
Union Electrician
byrd's Avatar
Question static drop w/20's
How low can I go using drop spindles and springs only without modding the inner fenders or tire rub issues. Wheels that are possiblly using are 20x8.5 (4.5 or5 backspacing)in the front. TIA ...Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 06-26-2007, 06:03 PM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: static drop w/20's
As low as you want. I would not do more than 3" springs 'cause it won't align. Go with at least 5.25 BS for a 8.5" wheel so that the wheel 'tucks' in a little; that will keep you from rubbing when you hit a bump.
I have done exactly this with a 255/70-15 which is the exact same as a 255/45-20 (29" tall). It could easily go another inch with no problems...
-Chris
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-27-2007, 12:20 AM   #3
droppedgmc
Truck Enthusiast
droppedgmc's Avatar
do you have truck arms in the rear? im running a 20x8.5 and 20x10 both with 4.5" of bs. no probs at all and im lowered 4.5/7. im also running an adjustable panhard bar to center the rear after i lowered it. tires are 255/40 and 295/40
pics http://67-72chevytrucks.com/vboard/s...d.php?t=244913
'85 swb
droppedgmc is offline   Reply With Quote
