Slowly getting CRSS...
on my 72 LWB i have drum brakes, a disc conversion would be nice but cant afford it. I ned to find smaller drums that dont have the cooling fins. Somebody on here said they had there's machined off but is there a 12 bolt car axle brake assembly that would bolt up? I know the drums are not the same width on the cars as the trucks. need to get it done to get my cragars to fit.
------------------ Lutz, Fl My Team Website The Heavy Chevy Website ------------------
-Nic Lutz, Fl My Team Website The Heavy Chevy Website ------------------
There is No replacement for Displacement... "If everything seems under control, you're just not going fast enough." - Mario Andretti |
why do you wanna do this for ?! those fins are there for a reason... no car ones are gonna work.
------------------ Randy- Lincoln, IL randy@ccaonline.com 2177353230 *many GM parts bought, traded, or sold -am parting out: '81 Cutlass Supreme Brougham current fleet: -71 C-10 350/CH465/3.07- basketcase, #1 -90 Cavalier 2.2L sky blue, a driver -84 Z28 5.0L/700R4/3.73 daily driver -84 Firebird/SE 2.8L/T-5/3.73/engine bad, project #2 -82 purple Trans Am, project #3 *Paint is overrated* © RSS Enterprises 2000 |
i wanna do this b/c i spent $400 on rear rims that dont fit that i am stuck with b/c they were special ordered. It is what the manufacturer suggested i should do. I well never be doing any hauling with the truck i see no need for extra cooling for the brakes
[This message has been edited by HvyChevy454 (edited May 09, 2002).]
howcome they dont fit ? the fins are not there just for hwen you haul weigh tin truck, they are there to cool off the brakes no matter how you use the truck, for the most part, if you use the truck in actual city traffic stop and go, then you will wish you had fins on them,.
good luck [This message has been edited by Fast68Chevy (edited May 09, 2002).] |
It was suggested by 2 different wheel manufacters to machine the fins on large backspaces on the wheels. The ralleys I am setting up have a 6 1/2" bs,& will clear the drums. I did also find that the replacment drums have a little less fin height than the stockers had(got lucky,no machine work). How much bs do the wheels have,& how far away from fitting are they?
http://community.webshots.com/user/hotrodhorn |
the wheels have 8'' bkspg abd are about 1.5 to 2'' from bolting up. same w/ my front rims, they dont clear the caliper, i have to get a 1'' spacer to make them fit which will mess up my offsetting, but i have no choice.
Can earlier drums from a 67-68 be redrilled? I know they don't have the fins.
------------------ Check out other members trucks 1968 50th Anniversary C-10 Suburban (Tows all these cars all over the place) 1968 50th Anniversary C-20 Pickup CST, Sold to Fine69 1969 SS Camaro Conv't 1960 Lakewood Travel Trailer 1963 Ford Falcon Wagon, Still For Sale Phoenix, AZ. Click Here for Parts and Venicles I have Available THINGS I AM LOOKING FOR: 67-68 SUBURBAN TRIM. $$$$ Reward for finding the 3rd door trim piece and the small piece that goes on the 1/4 panel right behind the 3rd door.Click Here to see the two pieces I need.
Just sitting here contemplating contemplation. |
CCRider
Take them to any place that turns drums and talk them into turning the fins off. If they have one of those cheapie machines that won't do it carry it to a machine shop,they should not charge more than one hour to do it. If you can find someone that works in a machine shop you should be able to get it done for a 12 pack
------------------ 72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
Do you know the specs on those? My drums are 11x2'' every car drum ive been able to find has been either 11x3.25 or 4. and the only way at Napa to tell if the drums dont have fins is to look at every one. The Napa i have near me is the main distribution for the southeast so that is about impossible.
Old member
I would look at selling, are trading the wheels in on a set that fit, before I went and had the drums worked on, but if you have to keep them I would grind them off myself. It's a brake drum it's not going to hurt it no more than it will be after your done. If the fins are solid would be my only concern. The time would might not be worth it though.A shop might save you a lot of time.
------------------ Andy 71's Are for ever!!! or 67,68,69,70,72 71,factory tach,tilt for straight drive,gauges,ac,speed warning,clock,305 HO TPI with 700-R4, lowered 2" & 3" ,and 17" Chrome Stealth wheels, Pioneer reciever,100 watt amp, 6 disc changer, 2-10" subs (behind seat) 2-6x9 in doors, 2-3ways mounted under seat, and 2 tweaters on door panels www.geocities.com/chevy71tpi/main.html www.picturetrail.com/Andy4639
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
i would love to trade them or sell em but they are too weird of application 15x12 Cragar SS w/ 8'' backspacing and Cragar only makes their 16'' rim 9'' wide.
You might try an aftermarket drum first,but I think 8" is pushin it on bs. I thought I was gonna have to machine the fins on a 6 1/2" bs(15" wheel,with largebore center....13 1/4 on the center). I went to Napa,& picked up a new set of drums to have machined(no point in spending cash on old drums that cant be turned again). As I said, I got lucky.....the replacemenr drums didnt have as large a fin area,& the wheels will fit,without machining....@ 6 1/2"bs. From what I saw when setting mine up,I dont think you will have to shave all the fin off,the most offensive area will be toward the back edge of the drum.......& I wouldnt loose any sleep over machining them if needed. I would check out Napa first,& measure a replacment drum vs the OE.........they were only $34.50 ea to replace. I also got a couple new pcs on my old truck at the same time.......& that always makes me happy! Good luck........69longhorn
