Old 06-28-2007, 09:28 AM   #1
424shee
how much to cut?
can someone tell me how much I need to cut off a stock set of front springs to get 3".I know if you cut 1 coil it will drop it 2" but how much for 3".it's on a 1970 1/2 ton.thanks
424shee is offline   Reply With Quote
Old 06-28-2007, 10:03 AM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: how much to cut?
I cut 1.5 coils and got about 3.5" However, I wouldn't recommend doing this. The truck rode like crap, and you could hear the spring bouncing around in the pocket when you went over bumps.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 06-28-2007, 10:38 AM   #3
SCOTI
SCOTI's Avatar
The rule of thumb is cutting 1 coil = 2" drop but not all springs are equal. You might get 2" on one truck & 3" on another.
Cut 1 coil & put them back in to see how much drop you get.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-02-2007, 10:58 PM   #4
70c10
67-72 Addict!
70c10's Avatar
1 and a quarter coils cut off will give 3" of drop.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 07-04-2007, 12:24 AM   #5
low '71
i dont suggest doin that just buy 3'' drops
alot less hassle
low '71 is offline   Reply With Quote
Old 07-04-2007, 10:56 AM   #6
424shee
I just want to do this to get me bye until I can get bag's.it's not a daily driver.thanks for the input
Old 07-04-2007, 06:45 PM   #7
SCOTI
SCOTI's Avatar
Just cut 1 coil & put the springs back in. Set the truck down & see where your at. If it's still too tall, trim another 1/2 coil.
Warning: Some trucks have issues w/running out of threads on the upper a-arm studs when cutting off enough coil to get 3" or more of drop. You might have to get new, longer studs if you go this route.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-04-2007, 09:09 PM   #8
jamis
F.A.S.T. president
jamis's Avatar
Yep listen to SCOTI
I have 3 " springs and I ran out of threads to get my caster adjustment like he said. I bought longer studs and made 1/2 spacers, so I dont have such a large shim stack.
F.A.S.T. President and Founder
Fabricators for the Advancement of Sawsall Technology
"A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis"
jamis is offline   Reply With Quote
Old 07-05-2007, 04:34 PM   #9
424shee
thanks guy's.I have 1 coil cut right now and I'm just waiting for some cooler weather to put them in.
Old 09-05-2007, 03:03 PM   #10
70short
Did you install them yet? I am real curious how it looks and how much room on the bump stops. Please keep us posted. My truck is not A daily driver either and I would like to do this MOD.
Gary
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 09-05-2007, 03:19 PM   #11
satin64
satin64's Avatar
if you go with aftermarket coils will you still run out of threads?any pics of the bolts you need to change?i was planning on cutting 1.5 to 2 coils when i swap on the disc setup.
satin64 is offline   Reply With Quote
Old 09-05-2007, 07:24 PM   #12
SCOTI
SCOTI's Avatar
Shorter coils (either cut or aftermarket dropped-coils) require more shims which can require longer studs. Some trucks dont need them (both my 68 & 74 didn't), others do.
The exceptions to this rule are adjustable a-arms or re-designed (shortened lower/stretched upper) a-arms.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
