07-01-2007, 09:15 PM | #1 |
Disk Master cylinder swap??
I was just wondering/ thinking, do you guys think if I swapped to disk brakes from a 73-87 pickup onto my 67, could I just use the master cylinder off of a 71-72 with disk brakes and one of those adjustable proportioning valves from Summit or Jegs to make it all work?? Would the M/C bolt up?? would I be better off with a prop valve from a 71-72 pickup too?? Thanks for any help you can give!!
07-01-2007, 10:26 PM | #2 |
Dave's not here, man
Re: Disk Master cylinder swap??
I'm pretty certain the master cylinder for a 71/72 will bolt up. I thought about doing this, but took a different route. Don't see why it wouldn't work, though. I think an adjustable prop. valve would be better than one for a 71/72, but I'm not 100% sure about that. Hope this helps you out some.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
07-01-2007, 10:36 PM | #3 |
Out of the carpool lane.
The m/c will bolt up no problem and I'd advise using the prop valve from the 71-72 as well.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
