surface rust
I lifted my carpet today and there is surface rust in the floorboard. What would be the best to treat this before it becomes a big problem.
thanks rickey |
Sierra Grande Club
Re: surface rust
Rust bullet.
![]() s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
Sierra Grande Club
Re: surface rust
That’s debatable, most people here will disagree with the use of naval jelly (and it does nothing for keeping the rust from coming back).
![]() s/t
Re: surface rust
Should I sandblast the area and prime the area. I just want to stay on top of it before I have to replace the floor.
Sierra Grande Club
Re: surface rust
When using RB you just need to scuff the area to remove anything that is loose, then brush it on. It’s that easy.
s/t
Re: surface rust
Where do you get RB. thanks for the tip.
Sierra Grande Club
Re: surface rust
Re: surface rust
this is what i've used in the past many times. It's simple to apply and as an added bonus it WORKS. You can get it at any hardware store. The only color i've used is the black. Hope this helps. http://www.rustoleum.com/CBGProduct.asp?pid=159
R.I.P. Killer 71 10/26/07 |
Re: surface rust
Thanks for your help.
