Miscellaneous questions from this weekend
I got up the guts to change over from points to electronic ignition on my I6 – I used a nova dizzy with the external coil, new wires and gapped the plugs to 45. It ran much smoother right from the get go. Cleaned up a good portion of the wiring harness. I then installed one of the two brake booster brackets, pulled my cowl and cleaned out three trees worth of leaves, lubed the wiper linkage (HUGE difference) and put the cowl back on. I have a bunch of assorted questions…
Q1 The vacuum module on the dizzy will hit the block as I turn it (tuning by ear) – I could turn it more before the engine would start to run bad (then turn it back a little) – but there’s not enough “turn” – Can I turn the dizzy housing to get more “rotation” room? I’m pretty sure I can but I’m having a brain bubble on this… Q2 As I turn the dizzy, the rpms pick way up. Once set, the idle is WAY too high (single barrel carb) – is this a spring/linkage adjustment or a jet one? If jet, which one is it looking at the carb? If I turn the dizzy back, the engine will settle down to a nice purr but if I give it any throttle at all, it bogs down to nothing. There is a little pop – pop as it’s idling at any setting – like two cylinders worth in the firing of all 6 – even did that with the points setup – not sure if this is normal (only I6 I’ve ever owned). Q3 How does the “round” booster support bracket get mounted? The flat one was no problem but I can’t figure out how this one goes on and I never seem to see pics of them installed here (I’d rather have the support even if not needed) Q4 On the front of the valve cover, two wires were just laying there – burnt off. One (dark green) was for the temp sensor in the T-stat housing. I hooked it up and sure enough, the temp light came on (it wasn’t hot and no shorts) so I guess that needs to be replaced. The second wire is dark blue and I cannot find another burnt end where it might have hooked up (can't find in any schematics either). It is run in the same original part of the harness that has the temp sensor, two pots on the carb and a sensor at the front of the block on the dr. side (all of these are wired up). The oil sensor is on the other side by the starter and that is hooked up. Any idea what it is/was for? Thanks for reading all that and any information is appreciated!
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! Last edited by Luvlegs; 07-02-2007 at 11:26 AM. |
Re: Miscellaneous questions from this weekend
slipped to page 2 with no responses - so TTT
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
my schematic shows a blue/black wire for the oil pressure sensor and a blue wire for the right turn signal. those are the only two blue wires it shows.sorry I cant help with anything else but ttt
69 shorty w/ 67 front clip ![]() |
#4 | |
Out of the carpool lane.
I wrote inside your quote:
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... Last edited by Brad; 07-02-2007 at 08:15 PM. |
Thanks Short and Brad - I also could not find the wires on any schematics and as soon as I can find my vacuum guage and rig up a temp. tach, I'm going to give that a try. Still curious where that brake booster bracket goes though.....
