Old 07-03-2007, 10:15 PM   #1
Huck
Huck's Avatar
slotted mags ID???
Anyone have a clue as to who made these slotted mags? Just got a set of 4 that are 15X7 6lug that just need a little polishing to be super. Any idea of what a set might be worth before I decide to keep or sell???
Huck is offline   Reply With Quote
Old 07-03-2007, 10:22 PM   #2
CG
BlahBlahBlah
Re: slotted mags ID???
They all look the same to me. Some of em have stampings, but I'm sure you already checked for that. Thats a nice size, I usually see em in 8's or 10's. Do you have caps and lug nuts for em?
Old 07-03-2007, 10:27 PM   #3
jamie72
jamie72's Avatar
cragers??? looks like the 3 hole centers... looks nice thou!!
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 07-03-2007, 10:45 PM   #4
They look like American Racing ones I had.I had two sets in the late`80s.I think they were the last ones available.
Old 07-03-2007, 10:49 PM   #5
lbpd719
Zappaphile!
lbpd719's Avatar
most likely an early "American" set..
The most collectible of that style was the "Shelby Cal-500", which was an actual magnesium wheel (100%), thus the name "Mags". American, Cragar, and several importers made them, however most were aluminum or some mixture of alunimum with magnesium.
Back side will tell you alot more about them though.. Cragars will be marked with a CM usually in the casting.. American's had the more dominant "3 hole" cap early on, moving to the captive cap with the "A". Cragars and Shelby's are commonly 4 hole caps. The correct Shelby caps will have a cobra on them and are a little more difficult to find.
Shelbys are also able to be spot by the way they are machined, and they were the only ones with a groove near the top of the bead on the rim.
1969 C20 LWB Camper Special - The Beater..
1998 Cheyenne V6 - 4/6 Drop - For The Son
lbpd719 is offline   Reply With Quote
Old 07-03-2007, 11:14 PM   #6
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
typicaly $100-200 for a common size like 15x7/8 a set
ive seen 10s and 4s go for 200 a pair
a few acttual halibrand all mag rims where asking 1500 a pair!!!!!!
trkklr77 is offline   Reply With Quote
Old 07-03-2007, 11:36 PM   #7
chosn 1
fabricator of anythng not wood
chosn 1's Avatar
halibrands dont have that recess around the center , they are typically held to the wheel by the center cap
chosn 1 is offline   Reply With Quote
Old 07-03-2007, 11:41 PM   #8
da-burb
"Ochre Ogre"
da-burb's Avatar
I have 1 pair of 8 lug Shelby 500's(looking for a matching pair BTW). mdillon was just out to my place last week and he has a set that looked just like that for his Wagoneer. I never knew it before, but same 6 lug pattern, same 7/16 studs.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 07-04-2007, 06:26 AM   #9
The only Halibrands I can think of had smaller/shorter holes with a slight ridge around the slots.Many slot wheels had more squared corners than the Americans,like the Jeep wheels.Many had the air valve in the rim and not in the slot like the Americans.These have the step in the rim and center like Americans.The 8-lugs that I`m most familiar with had differences from the 15" wheels due to heavier application and larger diameter.The step in the rim is more pronounces and the slots are closer to the rim.Here are some Americans in 8-lug:
Here are some that are not Americans:
Halibrand
These were called "dish mags" before we started calling them "slots".The name "mag" was a reference to all early racing wheels made of magneseum,but mostly the 5 spoke design was considered a mag.The others used another word to identify them,like "dish".
Old 07-04-2007, 08:25 AM   #10
Huck
Huck's Avatar
OK back to my 6 lug's----I have found some lettering which say FORGED and they appear to be individually serial numbered with a unique number for each wheel. The more I look at them, the more I kind of like the look so perhaps there is a way to firure out who made them, then find a source for center caps, and finally, what is the best way to clean them up???
There are plenty of light scratches and curb rubs but nothing really nasty. I think they will go nicely my my 68 SWB project truck and I like staying with 15" as tires are a whole lot cheaper then 16-17" etc.
Old 07-04-2007, 08:41 AM   #11
68GMC454
THE VILLIAGE IDIOT
68GMC454's Avatar
i fyou lived closer to me,,id buy them in a heart beat..i can never find these style fo rim..imo, the best looking rim ever made..would love to find another set for my 68...the sixe you got for the front,,and as deep as possible for the rear..
honestly honey,,i have no idea how that truck got here.
68GMC454 is offline   Reply With Quote
Old 07-04-2007, 09:32 PM   #12
I was just showing that I had a clue.I cleaned a set with Mother`s polish and the cames out nice.If they`re not coated and have alot of black spots,you can use etching wheel cleaner.I`ve used Eagle One with 000 steel wool,then polish.
Old 07-04-2007, 09:37 PM   #13
corn
I have those exact wheels on the front of my 69 not sure what brand they are but I was guessing Ansen sprints or Appliance...
corn is offline   Reply With Quote
Old 07-05-2007, 12:27 AM   #14
Big D
Big D's Avatar
I have the same wheels on my 70 GMC, I dont see a brand on them anywhere. My bet is American or maybe Ansen.
Used to be you could not give away an old set of slots, Now with the retro look in they usually go for a couple hundred bucks at swap meet. Id like to find a 8 bolt set for my 3/4 ton project
68 GMC
64 1/2 Mustang convert
A bachelor's life is no life for a single man."
- Samuel Goldwyn
Big D is offline   Reply With Quote
Old 07-05-2007, 12:56 AM   #15
cstanley
cstanley's Avatar
they look like the Ansen Sprint model A69 from American Racing. I think These are what will wind up on my blazer. a brand new set, polished, painted, or brushed runs $638 from pep boys (cheaper online.) they also make them up to 17x8s. those run about $700 a set.
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett
'72 Blazer Restoration Blog: http://sportchicken.blogspot.com/
cstanley is offline   Reply With Quote
Old 07-05-2007, 08:03 AM   #16
Huck
Huck's Avatar
Thanks everyone for their knowledge and input. I think I now know enough to be dangerous!! Will get stuff to clean them up and polish them to a bright luster----then will need to make a decision on tires. Will stay close to stock but perhaps just a wee bit bigger for kicks. Huck
Old 07-05-2007, 10:19 AM   #17
Solver
Solver's Avatar
I can't help identify your wheels but mine are ansen sprints and the bolt circle area is raised on mine rather than dished in like yours are.
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 07-05-2007, 03:54 PM   #18
2bits
2bits's Avatar
Gotta love slots... Wish I had them on my truck!
_______________
Thomas
'78 Silverado
'74 Monte Carlo
'47 Teardrop Trailer
East Texas Classics Local Club
2bits is offline   Reply With Quote
Old 07-05-2007, 08:10 PM   #19
while we`re talkin`slots,some old rides I ran slots on:
Can ya tell?
My AZ shorty.
Camperless.
Old 07-05-2007, 11:18 PM   #20
pooz911
pooz911's Avatar
http://www.roadsters.com/mag/
Dave Mann has a lot of info on the nostalgia wheels. check it out.
www.cardomain.com/id/pooz911
pooz911 is offline   Reply With Quote
Old 07-06-2007, 02:01 AM   #21
68shortfleet
I would bet money on those being factory wheels to the late 70's/early 80's jeep wagoneer. They only came in 15x7 factory for the jeep and they had that three screw center cap design.
Jason
68shortfleet is offline   Reply With Quote
Old 07-06-2007, 02:35 AM   #22
GREASEMONKEY72
GREASEMONKEY72's Avatar
so mine would be american racing wheels?
valve stem in the slot
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 07-06-2007, 06:55 AM   #23
jaros44sr
jaros44sr's Avatar
Hey Huck, let me know how you make out on the polishing, I think I have to do some sanding be for polishing. Deep stone dings! I just bought a flapper wheel to try out...
Bought a set of 5-15x10 for 500. Most I can read is made in Van Nuys Cali. I was thinking Ansen but don't know yet, valve stem is in the slot
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 07-06-2007, 07:07 AM   #24
They look to be Ansen Sprints,since the center is an outty.American and Ansen became one at some point,I don`t know how far back.They are nearly identicle.
Old 07-06-2007, 10:54 AM   #25
stllookn
Saving 1 truck at a time!
stllookn's Avatar
I used fine scotch brite pads from my local auto paint store then some Mothers. I was not going for the polished look...I like a softer satin finish like the original wheels...and yes...I know some of the originals were polished.
Before and after shots...only about 30 minutes per wheel.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
