![]() Join Date: Jan 2002
wanted p/s pulley for 350
I need a p/s pulley for a 69-72 chevy truck. I have the flat one with no off set. I think it fits a 307. I will consider taking a complete pump set up. I need one for a 350. Thanks....
55 Chevy original swb (big back window) 61 Chevy bubble top (427-5 speed) 67 Chevy stepside (Krusty) 68 Chevy swb fleet (Lola) 68 Chevy swb fleet 71 Chevy swb fleet ( future PB project) 97 crew cab power stroke 07 SS Trail blazer |
Re: wanted p/s pulley for 350
ttt
I have the whole set up here that came with the 350 I put in the blaz. I took it off because the blaz had one attached to the steering box. It worked fine in my buddies truck I bought the engine from. It is here in this link
http://67-72chevytrucks.com/vboard/s...d.php?t=239716
Mario and Mandy Hughesville, MD 20637 69 C10 305/350 71 K5 Basket case 75 K10 Rescue **Parting out** 77 MG Midget **Parting out** 15 6.7L Cummins |
I was just in the same situation. I went to the lacal J-yard and paid 17.00 for a used pump and pulley and hoses. I figured the pump was worth 10.00 as a core if I needed a new one and the pulley was worth 7.00. Check locally at the j-yards.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
