Old 07-04-2007, 07:11 PM   #1
CUSTOM 72
CUSTOM 72's Avatar
Body Roll With Air
Hello All
I Have Installed An Air Ride Kit In My 72 -- Now That The Springs Are Gone I Fine The Truck Has Alot Of Body Roll To It -- Dose Anybody Know If There Is And Aftermarket Sway Bar Kit? Or Would This Be A Custom Fit From A Newer Modle.
Any Advise Would Help.
1972 c/10 Custom, Long Box, 350 Small Block, Auto 3 Speed, Custom Wood box, Full Air Ride, 3" C-Notch, 20" Front & 22" Rear Tires, Snow White Paint, PT Crusher Handles,
CUSTOM 72 is offline   Reply With Quote
Old 07-04-2007, 07:28 PM   #2
72hotrod
72hotrod's Avatar
Re: Body Roll With Air
ECE front swaybar on ECE brackets. Everybody with these trucks for street driving ought to put on swaybars as their 1st modification; best bang for the buck for improving the overall driving pleasure IMO. Also, are your bags isolated from each other's air supply so as not to let air move between bags with shifting wheel load?
72hotrod is offline   Reply With Quote
Old 07-04-2007, 11:52 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
What kind of air system do you have? If you only plumbed a two way system, (one switch front/one switch back) and T'ed the two front bags together and T'ed the two rear bags together,... you will get alot of body roll. You are transferring all the air from one side, (of the truck), to the other side when you go into a corner. That's why most people run a 4-way system. That way you have air going to each bag seperately. I suggest the ECE front sway bar brackets (lowered version) or NO bracket at all. Just attach the sway bar bracket to the frame. Also use good polyurethane sway bar bushings.
Keith
Convert to disc brakes.
Old 07-05-2007, 01:55 AM   #4
HUEVUDO
HUEVUDO's Avatar
Hey bud. I bought a performanconline front sway bar. I love the ride. Big diameter tube and very very wide compared to my buddies sway bar. My is 2 1/2 inches in from the rims. It is sweet. Maybe I can get some time for a pic.
HUEVUDO is offline   Reply With Quote
Old 07-05-2007, 01:03 PM   #5
67chevemall
67chevemall's Avatar
try a front sway from a 3/4 tonn truck maybe.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
