Old 12-14-2002, 08:27 PM   #1
72Long_Bed
Shift Kit For Turbo 350
I need to know which shift kit i should buy for my truck,it will be for street/strip.should i get a Trans Go ,or a B&M
72Long_Bed is offline   Reply With Quote
Old 12-14-2002, 09:15 PM   #2
mooneyes
mooneyes's Avatar
all the tranny guys i ever talked to always said to go with transgo..but i've had 2 350 turbo's with trans go's and hated both of them..they both seemed to shift a split second after i banged the shifter..the b&m's i've had always shifted hard and exactly when i hit the shifter
Ken Lyons, Slippery rock pa
68 short step 327 t10 4 gear
72 2wd blazer project
70 lwb 305/700r driver
78 caprice project
02 cavalier D.D ( hate it!!)
mooneyes is offline   Reply With Quote
Old 12-14-2002, 09:59 PM   #3
mikep
Used to have a truck
mikep's Avatar
I'm going to give a second to that. All the tranny guys I have ever known swear the Transgo is the way to go but the transgo equipped transmissions I have had shifted like crap. I like the tire chirping B&M shifts . Probably the transgo is easier on the transmission and may in fact shift faster . Driving an automatic is emasculating enough as it is. I'd go with the B&M.
No truck :-(
mikep is offline   Reply With Quote
Old 12-14-2002, 10:19 PM   #4
72Long_Bed
T T T
Old 12-16-2002, 12:12 AM   #5
72Long_Bed
T T T
Old 12-16-2002, 12:34 AM   #6
crazy longhorn
Fabricate till you "puke"
I have a Trans go kit in my 400 t, & like it better than the B&M kits that I have ran inthe past. IMHO, the B&M kits have a very brutal shift even in the lower rpm ranges. The transgo is more civil cruising around town, but does get pretty "rowdy" when the revs are up. The old longhorn will lite em up going into pass gear, then lite em up shifting back up......
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-16-2002, 08:53 AM   #7
70c10
67-72 Addict!
70c10's Avatar
I like my B&M. Barks the tires with ease.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
