Old 07-10-2007, 11:06 PM   #1
skokie
skokie's Avatar
Vacuum Gauge Install
If anyone has installed a vac gauge can you tell me how you connected the hose to the back of the vac guage?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 07-11-2007, 05:37 AM   #2
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: Vacuum Gauge Install
I use copper lines and brass fittings. 1/8" internal diameter, I think. The nylon/plastic broke after a year, so I upgraded. I used a ready-made tap in the Offy intake, and left the carburetor untouched.
'68OrangeSunshine is online now   Reply With Quote
Old 07-11-2007, 05:32 PM   #3
skokie
skokie's Avatar
Anyone have any pics of this?
68 build thread
Old 07-12-2007, 05:46 AM   #4
'68OrangeSunshine
Sorry, I don't have a digital cam. My install was done in the late '70s when even the "Company" didn't have digital imaging.
Simple install. Find a position on either the carb or the intake [best] for a 3/8" brass fitting; run 1/8 copper line from "pickup" to rear of engine, then down to any hole in firewall, bending to position under dash where you want to put your gauge. Tighten it up to air tight and you're good to go.
Mine' s on a '68 C/10 Stepside -- L6 292, Offy intake, Edelbrock 1404 4-Bbl carb, Clifford headers. Gauge is Mooneyes. Indicates 18" Hg @ 700 rpm, no load. 3~5" Hg @ 2000 rpm 45 mph uphill. A jumpy needle means sticking valves. Great gauge.
