07-13-2007, 11:57 PM | #1 |
antbody runnin the msd setup ?
anybody got the msd ignition setup on there truck ? i was wondering if it really helps fuel milage ?
bob
I BELIEVE IN JOHN 3:16 |
07-14-2007, 12:31 AM | #2 |
Re: antbody runnin the msd setup ?
wanna know the same thing
1997 pontiac grand prix gt (daily driver) for now; 2004 dodge ram quad cab (wife's truck) 4.7; 2000 pontiac booneville (wife daily driver) 1972 chevy cheyenne 350 bored 40 over 700r trans 373 gears ( posi) soon to be daily driver; 2002 gsxr750 sold |
07-14-2007, 07:02 AM | #3 |
I've never noticed any MPG gains.
07-14-2007, 08:31 AM | #4 |
well what about power wise, can you tell a difference in throttle response
07-14-2007, 08:50 AM | #5 |
I have a 6AL, but put it on shortly after a rebuild several years ago. I really can't say whether it provides better milage or performance, since I didn't measure performance or milage before installing it.
My best guess, though, is that an HEI or good aftermarket distributor with a quality coil would probably satisfy the needs of at least 95 percent of us. The biggest problem with the stock HEI is that the stock coil starts to fade around 4500 rpm. A good coil will take that number above 6000. I don't know about you guys, but my engine rarely goes over 5000 (those times are fun though!!!). HomerJ
67 C-10 LWB "Cow-butt-spotted" (neighbor's term) - work in progress. 350/TH400/3.73 67 Chevelle SS Clone 454/TH400/3.73 |
07-14-2007, 11:35 AM | #6 |
PROJECT 7DEUCE
If you use msd carry along the stock hei set-up in the glove box I had the msd box go out and I was walking.....yep it sucked....BTW no milage gains that I could see..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
07-14-2007, 11:55 AM | #7 |
from what i can see on a mild(less than 500hp) street driven machine pretty much a waste of money with no real advantages// advertising hype at its best
07-14-2007, 12:42 PM | #8 |
thanks for the help. guess i,ll just go with a good coil and be done with it.
bob
07-15-2007, 12:32 AM | #9 |
Are you running a HEI set up? My truck has HEI and I took the control module out and the MSD works in it's place. A standard HEI set up put out 45,000 volt. Before I installed the MSD I was fouling out spark plug. Since I installed the MSD I don't have a problem with fouled out plugs. The throttle response did get better but I'm still working on the carb. for adjustment in the jets. I did put bigger spark plug wires on with low resistance to get the most spark to the plugs.
07-15-2007, 01:36 AM | #10 |
I run an MSD box with Protronix ignition modual and a Protronix high out put coil in my 50' Chev. I had a real hard time starting this truck with points. I also would get a slight hesitation under hard acceleration. Once I put in the ignition goodies it started up right away and the hesitation was gone!! My reason for the ignition install was never because of fuel milage so I can't be of help there but MSD is supposed to causes fuel to be burned more completely giving you a bigger bang for your fuel buck and also burns fuel more competely which aids with the pollution issue.
esll.
Tomorrow is for doing today's stuff. ************************************* This truck has just the right amount of energy for me! Author: Warren Lake .... (member) |
07-15-2007, 12:28 PM | #11 |
18 Till I Die
check this out
http://www.pertronix.com/ I put one of these HEI flamethrowers in, plug and play replacement. All new parts and it works flawlessly. I hit 7000 rpms and never missed a beat. I think MSD is overrated I have seen too many of my buddies trying to fix, repair or setup...IMO
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
