Harmonic Balancer problem
Well I thought I had snagged the right balancer and I did but I forgot to compare the old and the new. On the old balancer the keyway slot and the timing mark are almost lined up. On the new balancer the timing mar is at about 10 degrees. Besides swapping the balancer is there another way to fix this?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
Re: Harmonic Balancer problem
Get you a bolt on timing tab for that year balancer.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
What postion would I need to put it in? The current one is at 2 o clock.
Parts and more parts
I woud turn the engine over to TDC on #1 cylinder and see where the pointer needs to be.
Hellasick
![]() Join Date: Jul 2006
At some time, GM moved the keyway on the crankshaft, creating your (and my)situation with new balancers on old engines, (or old balancers on new engines. I have a Goodwrench 350 in my truck, put in by a previous owner. The original balancer was then remarked with a new timing mark. It lines up with 0 at TDC.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys |
#6 | |
#7 | |
![]() After work tomorrow I will head out and get it to TDC then create a new mark. Thanks
