Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 07-11-2007, 10:03 PM   #276
chris@bigjranch.com
KIDHLR
chris@bigjranch.com's Avatar
Re: Joined the Short Wheelbase Club *69 Tahoe Project*
Man this build just keeps getting better
Christopher Johnson
Project - Grafted In AKA the "KIDHLR"
Conversion - KIDHLR Meets LPG
KIDHLR 2.0 Rise of the diesel(a 6.5 powered 6 Door pickup)
Romans 11:17-22
"Branches were broken off so that I could be grafted in"
chris@bigjranch.com is offline   Reply With Quote
Old 07-11-2007, 10:04 PM   #277
Frizzle Fry
Frizzle Fry's Avatar
Originally Posted by hgs_notes View Post
I thought I may have had a line on those hinges for you, but I looked at the old pictures I took and it had barn doors. Sorry
Hey, thanks anyway for trying!
Frizzle Fry is offline   Reply With Quote
Old 07-12-2007, 12:09 AM   #278
Frizzle Fry
Anyone who has read this whole novel knows that this is my daily driver. So, I have to do the major work that takes it down for any period (a day or more) on the weekends. I can't wait to get the front bagged but just can't do it during the work week.
But I do find a few hours here and there on weekdays to knock minor stuff out.
So... I decided this had served it's time honorably and deserved a nice retirement:
No, not just the cap...
...and not just the filler neck
but first let's modify that a little bit.
I cut the neck back and drilled a hole in the inner tube so that the vent tube would still function:
here's why
and that cap is pretty "deep" so it will actually seal around that inner tube; thus the drilled hole
The Hagan door assembly I chose puts the cap at a 45* down angle to the side of the vehicle. Since the OG neck is more like 55-60* the tube was cut at the appropriate angle to accommodate:
A little protection and she's ready
Old 07-12-2007, 12:30 AM   #279
Frizzle Fry
Next up; prep for the knife:
I wanted to center the door in the stock cap position which meant putting the whole assembly off center. It's this way because the hinge is on one side:
I also wanted to avoid disturbing the stock "tunnel" that houses the filler tube. Here it is after drilling out some spot welds and removing the factory filler section
Old 07-12-2007, 12:42 AM   #280
Frizzle Fry
The door assembly had to be modified a bit to get it to fit in that tunnel:
On top of that I still had to take some material off the right and bottom of the door skin to get the box to fit in the tunnel. So I ended up with gaps on the top and left:
The hoses ended up needing to be trimmed back about 1"
Here's how it turned out:
Old 07-12-2007, 01:00 AM   #281
Frizzle Fry
I mentioned my driveshaft/floor spacial conflict. Well here's photographic evidence... You can see how close it is to that floor brace/seat support (this is with the rearend sitting where it would with no notch; frame on axle-tube):
...and at the trailing arm crossmember. Both the xmember and floor support just behind it will have to be clearanced:
So here's what the floor looked like:
...and now there's a 5" wide rift...
Looking forward; yep, gonna need more room here...
Old 07-16-2007, 12:42 AM   #282
Frizzle Fry
Front bags are in. I see no reason to go into any real detail on this. It's the same set-up most guys are running: Slam Specialties RE7's, ***************** upper plates/cups with lower cups cut down to 1.5" (I don't see how cutting any more would make a difference), and ECE 2.5" spindles.
Here's the pics.
First at full rear lift and about level in front (front will go much higher and rear is limited by shocks):
And aired out; front sets inners on tires (more mods to come...) and rear is as low as I can go without setting the trailing arm crossmember on the drive shaft, so for now...
Old 07-16-2007, 12:43 AM   #283
Frizzle Fry
Old 07-16-2007, 10:41 AM   #284
chris@bigjranch.com
KIDHLR
Sweet!!!!
Christopher Johnson
Romans 11:17-22
Old 07-16-2007, 02:53 PM   #285
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Great Work as Usual, Do u attract a lot of attention when ever you have it out for a Drive? Just curious how many people realize how much work has gone into this?
Please keep us all Inspired with your Mod's.............
Rick
toomanytoyz is offline   Reply With Quote
Old 07-16-2007, 06:38 PM   #286
Frizzle Fry
Rick
I actually don't think that many people have any idea what they are looking at. I still have people saying "nice suburban," and occasionally (one in 25 that actually look) I might get "did you shorten that?"
One guy followed me to the bank and asked a ton of questions. Turned out he was building a 72 crewcab from a burb
Another guy followed me to work the other day. Showed me pics of his beautiful 71-72 on his PDA. That was the day I drove it with no rear shocks
Another time a few guys gathered around it and snapped some pics in the Home Depot parking lot. I didn't actually witness it but was told by another guy who was parked next to it. He said they were checking it out for like 15 minutes and waiting for me to come out, but I took too long
Still, I think it just looks like a junker to most people, with the rusty tailgate, primer stripes, cracked windshield, missing trim, and tweaked front bumper. Until they try to race... Even then I let most people go, but occasionally I'm in the right mood
It'll definitely get attention after it's painted, but most people still won't know anything is unique about it other than the stance and wheels
Old 07-16-2007, 06:44 PM   #287
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Got mine loaded up and ready to drop off soon as your done w/ yours
Owner/Op: "TN Classic Transport Carriers"
Daily Driver: "HerNameIsRio" 68 GMC SWB
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Toy Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 07-16-2007, 08:10 PM   #288
toomanytoyz
Luv the Crewcabs
-Mike
I think that is one of the Greatest thing's about this Hobby, When you get someone who know's the vehicle & can see all the Detail's that have went into Shaping it, it make's it all the Sweeter.............
Thank Again for all the Inspiration.......
Rick
Old 07-17-2007, 10:04 PM   #289
rancid
rancid's Avatar
that thing is *****en, nice work. i will use this for refrence on my 4dr tohoe convertable.
rancid is offline   Reply With Quote
Old 07-17-2007, 11:32 PM   #290
Frizzle Fry
Well, I've had the bags for a few days and I can tell you it really does ride smoother. Just gotta be careful how low I cruise with those long tubes... Time for some 3/4 length headers, and bigger wheels for more ground clearance
Old 07-17-2007, 11:42 PM   #291
Frizzle Fry
Define "done"
Rick
I totally agree. I got some more props on it today as I was pulling into a parking garage.
Thanks. Can't wait to see more of that!
Old 07-21-2007, 02:14 AM   #292
slimbailess
slimbailess's Avatar
hey mike, i used shorty headers from hedman for a chevelle on mine, i'll send you some pics as soon as i can,i think the # is 68618 for the coated ones with a ball flange.....can't find my receipt, but they fit with only a little clearance on the passenger side frame....like i said, i'll get pics for you as soon as i can...slim
slimbailess is offline   Reply With Quote
Old 07-21-2007, 02:32 PM   #293
Frizzle Fry
Those are the ones I've been looking at. Here's the summit link. Pics would be awesome. Thanks slim!
Old 07-21-2007, 03:28 PM   #294
Frizzle Fry
So, I had this little issue with the drive-shaft/floor-support/trailing-arm-crossmember all wanting to share the same space. Here's the shot of that issue:
As an extraordinary matter of chance, I happened to have some 5" OD 1/4" wall tube sections 2.5" in length that I had acquired for my hidden liftgate hinge idea (thanks to Britian), which didn't pan out (going to try 60-66 Burb hinges on that thanks to Captainfab and Livewire64 )
Pic from when I was playing with the hinge idea:
Those 5" OD tube sections ended up being PERFECT for making room for the driveshaft. I'll let the pics speak for themselves:
BTW a 5" holesaw in a 1/2" chuck hand-drill can pack a serious kick
Old 07-21-2007, 03:39 PM   #295
Frizzle Fry
...and the crossmember:
You can't see it, but the majority of the welding is on the other side of the crossmember in the horizontally "flanged" area.
Next I'll flatten the bottom of the crossmember and make exhaust cutouts for my own version of the "extreme-drop-crossmember" without ever taking it out of the vehicle
Old 07-21-2007, 03:44 PM   #296
Frizzle Fry
But, first I have more pressing ground clearance issues:
Old 07-21-2007, 03:47 PM   #297
Frizzle Fry
The Rear will tuck rim now that I can actually use the notch. But that's only with the front up in the air to keep the headers from being crushed So for now, here's the aired out stance:
Old 07-21-2007, 04:19 PM   #298
prairewolf
You are an Artist.
I am humbled and inspired.
thanks for all the effort to post the pictures and story of it.
life is good,kent
prairewolf is offline   Reply With Quote
Old 07-21-2007, 04:24 PM   #299
Hart_Rod
Hart_Rod's Avatar
Nice engineering job, .
R
Hart_Rod is offline   Reply With Quote
Old 07-21-2007, 04:59 PM   #300
1LoC10
Insert Title Here
1LoC10's Avatar
looks awesome
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
