what do you get the 454 from???
what kinda car/truck do you guys take the 454 from? the 454 ss trucks? work trucks what? also what do you expect to pay for one in a wrecked something? i have a 350 but the 454 looks pritty tasty in that engine cmpartment
1986 c-10 swb 5/7 drop 20'' coys 1958 belair 2door |
registered IWATA user
again, i dont know anythin about motors, but mine came from a late 70's burb. the ones in the 454 trucks are dogs, heads suck on them. the key is getting some good heads.
-'63 Ford Fairlane 500 coupe, v8, auto, faded and rusty. awaiting built roller 302 and some flat black -'99 Honda Prelude. vtech/5spd. no pipe, no intake, bone stock. awaiting new top end. -01 GMC Yukon SLT 5.3 dented and scratched with a noisy tranny. Take off that Von Dutch hat before i stab you with a 000 Mack. |
actually the 74 pickup heads casting number 781 are some of the most sought after heads because of the they are open chamber with smaller cc's and they can fit the big valves in them and can be ported to flow just as good or better than a stock rectanglur port heads.
69 chevy short wide box project 70 GMC jimmy project |
Big Blocks are gettign hard to come by anymore. The junkyards around here don't have them. If they do, they will tell you they don't. Crate engines seem to be the way to go. You know that you're getting a new motor, and a warranty.
![]() Join Date: Dec 1999
i prefer them from a 73 pickup and i think the best heads stock are the 049's the later model peanut ports have alot of bottom end but lack mid and high rpms.id take a 454 over a 396,402 anyday,if anyone wants to trade their 454's for 396-402s i have plenty id trade
Registered truck nut
I think the best way is to buy a complete truck and snag the motor. The last one I got was in a 78 1 ton dually. After parting out the truck. I came close to getting the motor for free. Or buy the truck and pull the BB and replace it with a SB
MOUNT VERNON, WASH. STATE Need a part? Just PM me |
![]() Join Date: Aug 2001
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
Older cars in my opinion are the best resources for big block engines. Chevelles, Impalas, etc. But if you're looking for a more torquish oriented motor, head for some bigger trucks. But don't think about getting a 454 ss. They suck supposedly.
Brandon |
Johns70, wheni said they were dogs i meant the 454 ss newer ones, not any 454 truck motor.
what about 292 heads? are they any good?
454
I got my 454 out of a 75 3/4 ton. I had it rebuilt and was done by a speedshop. I'll pick it up by Friday. They ported the oval heads, 9.5 comp with a slightly domed forged pistons, weiand intake. I can't wait to drop it in my 72 Lonhorn.
Fayette Alabama |
Slowly getting CRSS...
mine came out of a 91 3500 series dually, the heads suck, it is basically a gas hog,w/ decent torque. with a cam and the usual bolt ons i was able to get a 100 hp out of it, now im up in the 330hp range.Its about all i can do w/ the small peanut port heads. The Gen. V-VI blocks are no way near as good as a Mark IV, which are 90 and older, their heads are not interchangeable, so you either have to go new after market, or GM Bowtie heads. as is it will light up 29x15.5x15 sportsmans from a stop, and in drive chirp going into 2nd, this is a LWB c10 and a stock TH350.
also when getting an older 454 know your numbers b/c people will try to pass off 366's as a 454 and a 366 is useless in getting high HP, but its good on the torque.
-Nic Lutz, Fl My Team Website The Heavy Chevy Website ------------------
There is No replacement for Displacement... "If everything seems under control, you're just not going fast enough." - Mario Andretti |
heads are the key to big power for big blocks, all big blocks make tons of torque but the bigger the heads the more flow and horse power.
the 292 heads must be retangular port becuase my book shows them as a 70 454 450 horse with 2.19 intake valves and 1.88 exhuast. but if you look at the better oval port heads they list casting #781,049,241,820,290 most of them have a 110 cc chamber, considerd a semi open chamber head which means more piston options to get the compression were you want it.good flow alsoaround 250 cc runners intake and 115 cc on the exhaust. the rectangular port heads are only running 300cc intake runners and 120 on the exhuast.
hmm, i'm positive that they're oval port, where can i look into this more? so they're pretty good, right? the guy said they were close to best stock head, besides vette's and stuff
#15 |
i'm not sure on the heads?my book just shows that they're off of a 70 high per.450 horse,maybe you got the numbers crossed?it says with that valve sive it should be recgtangular intake port.
