Old 07-18-2007, 09:03 PM   #1
68Stepbed
68Stepbed's Avatar
Lowering shackles
I ordered some 2" front springs and 2" rear shackles for my 86 from Summit racing. The company that makes them is Ground Force. The front springs shouldn't be a problem, but the instructions with the rear shackles say that I need to cut a section out of the cross sill support of the bed just above the shackles.
Has anyone else had to do this with shackles? Has anyone used this brand? Is there a better way to lower the rear just a couple inches?
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 07-18-2007, 09:10 PM   #2
mercman1951
mercman1951's Avatar
Re: Lowering shackles
My understanding was with the shackle kits: they were the easiest to install to get the back end lower...I'll be watching this thread since I plan to go this route too, and do not plan to have to make any modifications other than swapping these in...
other BIG project:
http://landyachts.homestead.com/index.html
mercman1951 is offline   Reply With Quote
Old 07-18-2007, 10:03 PM   #3
f.monroe
f.monroe's Avatar
I am pretty sure the leaf springs and shackles will interfere with the bed cross support . If you dont want to cut the bed , you might check on lowering springs for the rear . I believe Slonakers blue truck is dropped in the rear with springs . I dont know if they offer 2 inch drop springs but you might check with him to see where he bought his . Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 07-18-2007, 10:17 PM   #4
texassquarebodies
Truck Nut
texassquarebodies's Avatar
Unhappy Re: Lowering shackles
You are going to have to trim the cross bracing........ya I know.... I put bell tech 2" hangers on my 1982 chevy 10 years ago. It is one of those things you gotta do when ya wanna go lower....
Tony Kee
Texas Square Bodies
Truck Junkie
Last edited by texassquarebodies; 07-18-2007 at 10:19 PM. Reason: 2 words run together
texassquarebodies is offline   Reply With Quote
Old 07-18-2007, 10:47 PM   #5
77-383 Step
Yeh, you have to trim them. I've done this with the drop springs and it's still not very low. I'm kinda lazy/impatient and I love tools,,,,, so I bought a Plasma cutter to do it. worked out nice, but you could get it done with a sawz-all, no problem.
77-383 Step is offline   Reply With Quote
Old 07-18-2007, 11:24 PM   #6
bigblock73
yeller
bigblock73's Avatar
Before you cut the cross sill, look and see what springs you have in back. If you have the longer heavier duty 56" springs, you should not have to, if you have the standard light duty 52" springs, you will have to. Take a peek and let us know.
bigblock73 is offline   Reply With Quote
Old 07-18-2007, 11:36 PM   #7
slugish
Slugish
Wink Re: Lowering shackles
Dont Need To Cut Cross Sill With 2 In. Hangers , Add The 2 In Shackle For Another 2 Ins & You Have To .
Have Light Duty 4 Spring Set Up On My 84
slugish is offline   Reply With Quote
Old 07-19-2007, 12:21 AM   #8
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I have 4" Western Chassis drop leaves from performancesuspension.com. AFAIK, they don't make any for a 2" drop. You could use them and 2" blocks, but that would be a lot off trouble to go to in order to avoid cutting the bed support.
You may have the longer springs. I have the shorter length springs, and the bed support is directly above the shackle. It would have to be cut. That is one of the reasons I went with drop springs.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 07-19-2007, 12:32 AM   #9
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
As Jeff indicated, if you have the standard suspension which is the 3-4 leaf setup, you have to cut the cross sill and if you have the HD setup, you don't.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Last edited by Captkaos; 07-19-2007 at 12:32 AM. Reason: didn't want anyone to confuse 3/4 for 3 quarters... it is really 3 or 4...
Old 07-19-2007, 07:12 AM   #10
68Stepbed
68Stepbed's Avatar
I'm pretty sure I have the light duty springs. The spring eye and shackle is about an inch right below the support. I can't afford new springs and I don't want to cut up my bed, so I guess my truck will keep it's nose bleed stance for a while longer. The springs and shackles only cost about $125.00 from Summit. I guess you get what you pay for, huh.
Matt
Old 07-19-2007, 02:47 PM   #11
xtreme80
Wishin' I had more money!
xtreme80's Avatar
It's really not much of a cut. It's just one little spot above the shackle. Good chance nobody would even notice
xtreme80 is offline   Reply With Quote
Old 07-19-2007, 07:20 PM   #12
tyjoja
just cut my 73 bed rails in the back with a sawzall no problem, had to cut a small section wich does not affect strength would be hard to see. had to pull the bed off, 8 bolts and four people, disconnect the lights and the gas filler hose. flip it over and paint an undercoat the bottom of the bed and the frame while you have it off. Mine turned out nice. go for it. bob
tyjoja is offline   Reply With Quote
Old 07-19-2007, 07:31 PM   #13
tyjoja
on second thought, and correct me if i'm wrong I think the lowering shackle are on the front part of the springs and require no cutting of the bed at all. you just pop the old four rivets to the frame off and bolt the new ones on. still easier to pull the bed as above, and I used a cold chisel and a 3 pound heavy hammer, and that will lower your back 2" I used shackles with spring hangers to add up to 4 1/2" total. lol
Old 07-19-2007, 07:51 PM   #14
Captkaos
Captkaos's Avatar
Price is reasonable for shackles. They are longer (significantly) that the stock ones hence the need to clearance the cross sill. You could do it with a sawzall or a cutoff wheel or a grinder if you had to.
Incorret, that is a Hanger.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 07-19-2007, 11:59 PM   #15
benoit454
Chris
benoit454's Avatar
exactly spring hangers are the front and there's 6 rivets I'm pretty sure, and the shackles are in the back.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 07-20-2007, 07:40 AM   #16
piecesparts
Parts and more parts
piecesparts's Avatar
If you are hanging new (longer) shackles, then the rib, just above and behind the spring shackles will need to be trimmed. I cut mine and then put a filler piece into it for more strength. I have done more than one truck and had to do everyone of them, that way.
Old 07-23-2007, 07:35 AM   #17
68Stepbed
68Stepbed's Avatar
What about just running new hangers in the front for a 2" drop?
Matt
Old 07-23-2007, 08:57 AM   #18
454HO
This is the way my truck was set up before I tore it down for the rebuild a few years ago. The only negative affect I noticed is that it had a little bit more of a tendancy to wheel hop when accelerating hard. I suspect it was because of the pinion angle change. Lowering hangers on the front rotates the pinion yoke upward. There are leaf spring wedges available that you can use to correct this though if it's a problem.
- Greg
454HO is offline   Reply With Quote
Old 07-23-2007, 04:56 PM   #19
piecesparts
This puts the rear axle at a bad angle to the driveline. Use the rear shackles first, then do the front hangers.
