Old 07-19-2007, 09:30 AM   #1
sdailey
The Few, The Proud
sdailey's Avatar
WIW 3/4t Axles
I'll be removing the 3/4t axles from my truck here shortly to replace them with some 1/2t ones from a donor truck.
What are these axles worth? I'm unsure of the gear ratio at the moment.
Dana 44 closed knuckle w-drum brakes up front
Eaton/HO52 w-drum brakes in the rear
Shannon
sdailey is offline   Reply With Quote
Old 07-19-2007, 09:34 AM   #2
1969k10stepside
Re: WIW 3/4t Axles
I'd say $150-$200 for the pair.The rear would be worth the most since the front is a closed knuckle.
1969k10stepside is offline   Reply With Quote
Old 07-19-2007, 09:42 AM   #3
sdailey
The Few, The Proud
sdailey's Avatar
Re: WIW 3/4t Axles
Thanks Dustin.
Shannon
Old 07-19-2007, 02:03 PM   #4
Re: WIW 3/4t Axles
I`d say around $300.A pair of 8-luggers is a cool upgrade for the zillion 1/2tons out there.The slightly antiquated axles wouldn`t be such a drawback on a custom-build.They also have a value to the limited original restoration crowd.You may need to sell for $150-200,but let them go to use and not scrap,whatever you do.The parts are worth $150-200.
Old 07-31-2007, 08:51 PM   #5
atltd4x4
Re: WIW 3/4t Axles
How much for the eaton rear end?
atltd4x4 is offline   Reply With Quote
Old 07-31-2007, 09:53 PM   #6
goldengoat2
Re: WIW 3/4t Axles
I a'm also removing my closed knuckle axle out of my 67 3/4 ton 4x4, I will have a spare 3/4 ton closed knuckle with no new home.
65 tripower conv 4spd gto, 66gto, 67 gto
65 lemans conv 4spd
69 firebird conv.
67 c20 4x4
goldengoat2 is offline   Reply With Quote
Old 08-01-2007, 07:55 AM   #7
sdailey
The Few, The Proud
sdailey's Avatar
Re: WIW 3/4t Axles
Sent you a pm.
Shannon
