69 C20
![]() the farther away you stand, the better it looks... |
its all about the +6 inches
Not too shabby...you gotta be standing at least a block or two away for mine to look that good. Fog and rain and tall grass makes mine look better too.
registered IWATA user
nice truck. is that a stock color?
-'63 Ford Fairlane 500 coupe, v8, auto, faded and rusty. awaiting built roller 302 and some flat black -'99 Honda Prelude. vtech/5spd. no pipe, no intake, bone stock. awaiting new top end. -01 GMC Yukon SLT 5.3 dented and scratched with a noisy tranny. Take off that Von Dutch hat before i stab you with a 000 Mack. |
![]() Join Date: Aug 2001
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
![]() Join Date: Jun 2000
That must be the perfect distance b/c it looks great from here. I assume it's yours? I was beginning to wonder if you owned a truck.
Ben '68 Chevy C10 Custom LWB 327/TH400 2nd owner '16 GMC Sierra 1500 SLE Dblcab 4wd 5.3 |
307 with 4 speed
When I got it the clutch was like a switch, either on or off. I guess it must have sat for a while. After about 1,000 miles it loosened up and now it works well. The rear shock mounts are all messed up - whoever put the posi axle in welded some brackets on top of the axle, so the shocks are just about bottomed out when the truck sits level. Some day I'll get around to putting the correct brackets in (under the trailing arms) with a new pair of shocks. I treated the cooling system with 'Ceramic Coat' (or something like that) which did a great job of closing up the leaky head gaskets. I went from billowing clouds of white smoke to a little blue-grey smoke, mostly on the right side. The right side plugs are pretty oily looking - I think the valve guides are loose. I'd like to tighten the motor up but that really means replacing it. Since it runs pretty well I don't have any pressing need to drop a couple of grand into it. I mounted the spare in the bed to get it out from under where access is a chore, especially with a flat rear. I made a plywood toolbox that fits perfectly, locks into the bed and comes out in about 5 minutes, solo. I also burned a hole in the new seatcover with a too-hot lamp while fixing the heater and fan controls. Doh! A new CD player provides the essential tunes ... Crazy Horse, Santana, Pink Floyd, etc. |
Nice truck, I like that color alot!
Registered Abuser
Thats a good looking truck Nucleus. What's the lumber for? Is that a six by six beam or an optical illusion?
(Just curious I used to be a carpenter for a living) |
Nucleus,
Good looking truck and I like your taste in music as well... Pete.
1968 Chevy - 3/4 Ton - 4X4 - Longbed - 383ci - TH350 - NP205 Building the motor, painting the engine bay, rewireing everything... (775)-527-1199 / ryanspeterson@msn.com |
Hey looks great. I also like the color.
69 3/4 ton 4x4 gmc with 6" sky jacker soft ride. 350 / th350 / 205 work in progress |
marcuspboldt
8" x 8" white oak - I was doing some timber frame repair on a house from about 1680. |
#12 | |
Led Sled! Discs R 4 ME!
![]() Join Date: Jan 2001
White oak..
Is the house your working on all heavy timber with mortise and tenon joints. I did one a while back like that. It was very interesting. We went to blow the walls with cellulose and found out that there was brick between the studs. My guess is that it was there for insulation or to stop the bullets during the war. ![]() ![]() |
Good Looking Truck!
