Old 07-16-2007, 05:39 PM   #1
bigo181979
Junior Member
bigo181979's Avatar
Air Suspension Help Needed...
I think I have decided that I want to go with air ride now. I already have all the stuff that comes in the A.R.T. kits but the bags, cups and plates. My question is: is their some where I can just by the front and rear bags and cups and plates for my truck (1968), I am just trying to save a buck by not buying parts twice. Any ideas, w/ part #'s, would be appreciated.
bigo181979 is offline   Reply With Quote
Old 07-16-2007, 05:42 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Air Suspension Help Needed...
www.*****************
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 07-17-2007, 12:42 PM   #3
bigo181979
Junior Member
bigo181979's Avatar
What brand of bags seems to be the best quality, and I mean ride quality too. I don't know to much about air suspension so I am trying to learn. Also how do you attach the rear bags? I saw the plates and cups for the front but what do you do on the rear???
Old 07-17-2007, 12:44 PM   #4
bones
slam specialties are probably the best bags out there... your going to want to use the 8in bags. and depending on how you want it setup you can do bag over axel or bag on bar
bones is offline   Reply With Quote
Old 07-17-2007, 01:18 PM   #5
bigo181979
Junior Member
bigo181979's Avatar
I was thinking bag on bar would probably be the way I want to go. I am not intrested in putting in a 8" notch or cutting up my bed and stuff I want the truck to look like it came that way from the factory. I have a cpp c-notch already for the rear.
So how do you go about mounting the bags where the stock springs were?
Old 07-17-2007, 04:58 PM   #6
SCOTI
SCOTI's Avatar
The bottom of the bag bolts right in like the stock springs on the trailing arm. For the top of the bag (where the air fitting is), you'll need to drill the 3 required holes in the bottom of the frame.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-17-2007, 06:06 PM   #7
bigo181979
Junior Member
bigo181979's Avatar
I was looking at the slam specialties bags and I see they make 3 different psi rated bags a 200, 400, and 600 psi bags, I plan on still pulling a boat trailer on the weekend with my truck so what would be best and do I run the same size and psi rating bags front and rear, say 400 psi??? the boat ways about 4000lbs and my half ton silverado pulls it great and dosen't squat but about an inch or two. Oh and I am running a small block in my truck in case that matters.
Old 07-17-2007, 07:51 PM   #8
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
I plan to pull a 4000 lb. trencher with my truck and am waiting on my Re-7's to come in
I'm gonna be run'n Re-7s all the way around
I dunno why you would want to run a Re-8, like Bones suggested
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 07-18-2007, 09:27 AM   #9
skunkwerx
skunkwerx's Avatar
this is the bracket i made so i didnt have ot drill holes in the frame.
skunkwerx is offline   Reply With Quote
Old 07-18-2007, 11:06 AM   #10
bigo181979
Junior Member
bigo181979's Avatar
Skunkwerx, do you have a pic of your truck all aired out? About how far are you from laying crossmember/frame and what size tire you running? What bags are you running also?
Old 07-18-2007, 01:14 PM   #11
skunkwerx
skunkwerx's Avatar
what size wheel do you want to see on it,i have pics of 18/20,20/22,20s&15" with with walls?bags are firestone 2600lb.
Old 07-18-2007, 04:42 PM   #12
bigo181979
Junior Member
bigo181979's Avatar
The 20/22" combo, I am looking at actually running 22" all the way around on mine. Are you running a c-notch or a step notch?
Old 07-18-2007, 11:15 PM   #13
skunkwerx
skunkwerx's Avatar
the front still has the inner fenderwells,about 1.5"off the ground.the back is just a bolt in c-notch.
Old 07-19-2007, 03:24 AM   #14
BigShoe24
True Addiction
BigShoe24's Avatar
Looks good skunkwerx, Were in Oklahoma are you from?
BigShoe24 is offline   Reply With Quote
Old 07-19-2007, 08:35 AM   #15
drbyrdman
drbyrdman's Avatar
I want my 67 to sit like yours. What did you do? I see a c-notch. Spindles up front?
drbyrdman is offline   Reply With Quote
Old 07-19-2007, 10:01 AM   #16
bigo181979
Junior Member
bigo181979's Avatar
What size tires you running front and rear???
Old 07-19-2007, 10:03 AM   #17
skunkwerx
skunkwerx's Avatar
i live in sayre, ok west on I-40.
in front i have spindels,bag in place of coils.in the rear i have bolt in c-notch,2"lowering blocks,extended pan bar,bag in place of coils&1.5"spacer on top of bags.
Old 07-19-2007, 10:05 AM   #18
skunkwerx
skunkwerx's Avatar
this is a pic of the front crossmember with 18/20"wheels on it.
Old 07-19-2007, 05:11 PM   #19
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
What is the total hight of your front tires ???
And at dump are you rubbing your inner fenders
Sinister
Killer
Old 07-20-2007, 10:23 AM   #20
skunkwerx
skunkwerx's Avatar
245/35/18 dont know how tall it is off hand,but no it dnt hit the inner fender.
Old 07-20-2007, 01:19 PM   #21
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
The 1.5" spacer on top of the bags? Is that in the front or back? Does that make it lower?
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 07-20-2007, 02:53 PM   #22
1LoC10
Insert Title Here
1LoC10's Avatar
how about 22's and 24's... oh yeah
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 07-20-2007, 03:57 PM   #23
SCOTI
SCOTI's Avatar
The 'spacer' is for the rear bags.
It does not make it lower.
The 'spacer' makes it easier to install the bags because it eliminates the need to drill the required holes in the bottom of the frame rail.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-20-2007, 05:21 PM   #24
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
skunkwerx
Can I get you to measure how tall the tires are
Also, what drop spindles do you have 2" 3" ???
Sinister
Killer
Old 07-20-2007, 05:33 PM   #25
MrShelley
Too Many Clubs Club
MrShelley's Avatar
245/35/18 = 24.75" tall
How I installed my air bags...
MrShelley is offline   Reply With Quote
