Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 07-21-2007, 05:16 PM   #301
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
Re: Joined the Short Wheelbase Club *69 Tahoe Project*
your definately gonna have to get some shorty headers, as always i am impressed, i wish i could do the type of fab work that you do!
good job!
cant wait to see the next set of update pics
tommie is offline   Reply With Quote
Old 07-21-2007, 07:34 PM   #302
wagonhoe
wagonhoe's Avatar
Nice... I can't wait until I can do some work on my '69. You are a true inspiration and a frustration all at the same time.
1969 C10 Suburban, 396cid, Turbo 400, 9" F***, Disk brakes all around
1968 C10 Suburban, 350cid, 700R4, bent frame
1968 C20 Suburban, no motor, trans or interior (SOLD!)
1953 Packard Ambulance
1992 Caprice wagon
wagonhoe is offline   Reply With Quote
Old 07-25-2007, 04:51 PM   #303
Frizzle Fry
Frizzle Fry's Avatar
Thanks guys.
I was getting sea sick with no swaybars so I had to make getting them back on a priority. I don't know how anyone can stand it without them
So for the front I cut 1-1/8" off the ends of the bar. Without doing so the bar ends would touch the bags when sitting low. I also made some "brackets" to hang the bar down from a the fame a bit (was mounted directly to the frame before). The ECE brackets would probably work fine here, but these could be here TODAY
The reason I have to use brackets now is that the bags allow it to go low enough to cause interference between the bar and steering/pitman arms. Now with these brackets installed the cotter pins on the castle nuts almost touch the bar when fully aired out and steering at one lock or the other (sorry no pics of that). I can live with that because #1 I won't be driving aired-out and #2 I won't be turning the wheels to full lock when aired-out and #3 it doesn't touch .
Here's the pics of that:
I also found that the rear was hanging up on the right side. The ECE Super-track Bar bracket was hitting part of the notch. So I moved the bracket from above the lowering block to under the lowering block, trimmed the bracket, and trimmed the notch where the inner plate was hanging over (notch not yet trimmed in this pic):
That got me down lower in the rear. In fact it's at the point now where the gas tank will touch the ground before the suspension bottoms out (time for some bigger wheels):
Frizzle Fry is offline   Reply With Quote
Old 07-25-2007, 04:53 PM   #304
Frizzle Fry
Here's the true aired-out rear suspension with the help of jack stands:
Good use of the driveshaft clearance. It does not touch anything when fully aired-out
Old 07-25-2007, 05:03 PM   #305
Frizzle Fry
The reason I left the notch at a full 8" even though I don't want to "lay-out" was so I could run the Camaro rear sway bar I have been using. This set-up is especially nice for lowered trucks when you don't want something hanging down below the trailing arms as some of the aftermarket rear bars do.
I ended up grinding down that outer/rear edge of the inner notch plates to gain clearance for the swaybar. Also, I'm not totally satisfied with the mounting tabs that are welded to the notch. I think I'm going to run some 2x2 through both notches to serve as a bridge and swaybar endlink brackets. Here's what it looks like now (2nd pic):
It's good to have it handling "properly" again. Now I need to do some cleaning up of the lines etc back there. Once I figure out the final config I'll POR-15 all the bare metal.
Old 07-25-2007, 05:48 PM   #306
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
It was a huge pick me up for "Merlot" after the 1-Ton bar went on
Drove about 150 miles Saturday & never checked that.
Boy was I scared when I read this, but I had over 1 fingers thickness
between mine and the bags. Wonder why yours was into the bags? I
guess we could have a different type of bag up front. Looking good
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 07-25-2007, 06:05 PM   #307
Frizzle Fry
I've got a 1.25" bar too. So nice
Mine may have been located further aft than stock when I drilled the bushing/bracket holes in the frame. I have SS-RE7's.
Old 07-25-2007, 06:07 PM   #308
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
OIC, No idea what bags I have, but I have the ECE lowered brackets in
the stock locations, so that could be part of the differance on mine.
Old 07-26-2007, 08:41 AM   #309
67ChevyRedneck
67ChevyRedneck's Avatar
WOW, never saw this thread before... this is seriously the coolest thing I've ever seen done to a 67-72 truck.
Here's the "Argentina" version! I think yours is shorter, but same idea. Notice it also has "truck doors."
This is a real pic, not a photoshop posted by GMCbsas
http://67-72chevytrucks.com/vboard/s...ight=argentina
It's on page two. There's also an "avalanche" looking truck too!
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 07-26-2007, 09:06 AM   #310
Hart_Rod
Hart_Rod's Avatar
The section between the front and rear doors looks very similar to my crewcab. I wonder if that was were it was built?
R
Hart_Rod is offline   Reply With Quote
Old 07-26-2007, 09:29 AM   #311
67ChevyRedneck
R
Could be? Or maybe it was a GM prototype for overseas that never made it to production?
I didn't realize this until recently, but GM DOES design and test a lot of their overseas cars HERE, even though they are not for sale in the US.
Check out the Chevy Lumina SS, for sale only in the middle east. The pics were taken by GMInsider in Michigan.
Jesse James
Project "On a Dime"
Old 07-26-2007, 10:02 AM   #312
72 Cheyenne402
72 Cheyenne402's Avatar
What size adaptors are you using in the rear? What size wheels and tires?
1972 Cheyenne 402 LWB
2005 Silverado X-Cab 5.3L
2004 John Deere L120 20HP B&S
72 Cheyenne402 is offline   Reply With Quote
Old 07-26-2007, 01:51 PM   #313
Crank
Crank's Avatar
Man Frizzle, I may have to purchase a 'Burban and send it with a check in the glovebox for you to do up for me, you are very innovative and with everyone seeming to do the same thing, you've managed to break out of the norm, congrats.... PS, if that Lumina SS was sold in the US. I'd buy one TONIGHT!
Brandon
Crank is offline   Reply With Quote
Old 07-26-2007, 04:00 PM   #314
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
subscribing
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline   Reply With Quote
Old 07-26-2007, 07:16 PM   #315
gringoloco
A guy with a truck
gringoloco's Avatar
Man, This thing is gonna look great with the new wheels on it. Hurry up and get some tires!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 07-29-2007, 06:35 PM   #316
Frizzle Fry
That's interesting. I wonder why they didn't just make it the way I did; at least they could have used the Burb doors
Old 07-29-2007, 06:42 PM   #317
Frizzle Fry
The adapters were to go from 5x5" to 5x4.75" bolt pattern. They are 1.25" thick. They won't be used when I put on the new wheels (they'll probably go on the parts board).
The wheels are from a late 90's/early 00's Mustang. They are 17" dia by I think 8.5" wide. The rear tires are 275/40/17.
Old 07-29-2007, 06:45 PM   #318
Frizzle Fry
Brandon
Originally Posted by sixty8c10 View Post
subscribing
Thanks guys. I don't know why we don't see this done more. Hopefully now we will
Gringo, I just got back in town and had a notice from FedEx on my door!
Old 07-29-2007, 09:19 PM   #319
72 Cheyenne402
Thanks for the info. that burman is awsome almost makes me want to trade my cheyenne for one. Whick tire and wheel setup are you going with?
Old 07-29-2007, 10:33 PM   #320
Frizzle Fry
The wheels are 20x8.5 and 22x9 Coy C5's and the tires I'll have to figure out when the wheels get here. I'd like to squeeze a 305/35 or 305/40 out back and 255's up front.
Old 07-29-2007, 11:34 PM   #321
72 Cheyenne402
Sounds great you will have to post some pics when you get them. I'm doing 18 & 20's with 245-45-18's on the front and 275-40-20's on the rear. I ent with the Centerline Voltage wheels. I just have to get my tires now.
Old 07-31-2007, 01:56 AM   #322
Frizzle Fry
Well, since the wheels weren't delivered today I had to let the creative juices flow, so I messed with the 60-66 Burb hinges I just got from Captainfab. Here's a little preview (that cut-out section will be re-installed):
Old 07-31-2007, 09:18 AM   #323
67ChevyRedneck
Cool video!
Jesse James
Project "On a Dime"
Old 07-31-2007, 05:10 PM   #324
Frizzle Fry
Wheels
and just to show it with the rear aired out:
Old 07-31-2007, 05:33 PM   #325
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
That is SWEET!
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
