![]() Join Date: Aug 2006
Where to go to shorten my rear axel?
Well, I have to shorten my rear end almost 6". I knew i had to shorten it but 6" caught me way off guard. So i was hoping to get some guidance. Where should i go to get it shortened? Also what do you think it might cost? Is there anything i should make sure they do or is it a pretty simple job. Thanks ahead of time.
Josh
(Project truck) 1970 C10 under complete transformation ![]() My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
Re: Where to go to shorten my rear axel?
what pasrt of CA are you in? North-south?
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
I am actually central cali but i do alot of work in northern side of Cali in San Jose. Any help would be much appreciated.
Josh
Designated A-hole!
Why so short?
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Well i just bought my bed and i measured it out to be 71.5" and my width of my rear end is 77.25" with my wheels and tires on.
Designated A-hole!
gotcha
expect to pay $800-1000 to get the job done
You need to "narrow" the rear axle housing and shafts,right?Like what Currie Enterprises does?What`s up with your truck?Tell more about it.What bed do you have?What points did you measure from on truck and axles(tires)?What tires and wheels do you have?12-bolt coil rear?
I am a Referee of life.
I would get some quotes on what it will cost.It may be cheaper to buy a narrowed rear from "Currie" or someone.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#10 | |
I would like to stay with a 12bolt because i already have rear disc brakes and don't want to redrill the rear axels again unless that is my only option. Does anyone know if there is any cars with a 5x4.75 bolt pattern that i might be able to take the rearend off and make it work? Thanks for your help. josh
(Project truck) 1970 C10 under complete transformation ![]() My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold Last edited by abadsvt; 07-21-2007 at 11:50 AM. |
WOWOWOWOW. THat is a little more than i thought. I hope it is a little cheaper. I thought it would be around $400-500. That sucks.
yeah well when the meter is running and you get the custom axels bearings seals add labor for the custom jig welding the bottom line gets up there
Before i go and modify my rear end, do you know where i can find widths of other 12bolts for other cars? Maybe i will be able to just swap my rear end for a narrower one and maybe save a few bucks.
Thanks Josh
#14 | |
6" does seem like alot though (3" ea side). If you're trying to ensure the outer edge of the wheel/tire clears the inner bed structure, remember it will have a visual impact. My truck would also use a 4.5 ~ 5"BS on a 10" wheel. 3" each side would pull the wheel/tire combo in too far & give it the 'over-narrowed' look you sometimes see on custom cars. I suggest getting the bed installed & aligned on the frame & roll the wheel/tire combo underneath. Set them up so they look like what you want (spacing vs. the body panels) & measure for the proper axle width.
#15 |
i am going to narrow my housing myself and from what i have seen of your work you would have no problem doing it too. just take your time and make a good jig to keep everything straight. as for the axles a friend told me they could be resplined for around 150 but i dont now for sure i thought the splined end was bigger than the shaft i have not taken them out yet so i dont know for sure. by the way i love everything you have done so far, it was your build thread that convinced me to build my own chassis. so thanks and keep up the good work!
