Old 07-21-2007, 11:36 PM   #1
MisterE72
Keep Your Nose Clean
Talking Got some work done today. Check it out.
My cousin came over and finished welding in and smoothing out my c-notch kit. He also welded in some steel rings for extra support on the exhaust holes I cut in the crossmember. Lastly, he welded some nuts on th inside of the frame so I can bolt up the gas tank from below without using the straps. Special thanks to Krue for the great step by step in the FAQ index thread. You rock Krue
MisterE72 is offline   Reply With Quote
Old 07-21-2007, 11:42 PM   #2
MisterE72
Re: Got some work done today. Check it out.
I forgot the pics. Here they are.
Old 07-22-2007, 12:41 PM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Looks great man! Can't wait to see some more pics...
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 07-22-2007, 01:11 PM   #4
Joes69c10
Proud Father
Joes69c10's Avatar
As Fonzie would say Looking Good.
1969 Chevy C/10 "My dad's, May he rest in peace"
1988 GMC Suburban 1/2 ton 2wd
1952 Ford F-600
1989 Toyota P/U "The Beater"
Joes69c10 is offline   Reply With Quote
Old 07-22-2007, 01:19 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Nice progress is always good....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 07-22-2007, 02:48 PM   #6
MisterE72
Thanks guys. You think I might have future issues by not using the gas tank straps and going with the direct bolt on to frame method?
Old 07-22-2007, 05:44 PM   #7
I would say yes, you get fuel in the tank and that is a lot of weight on those tabs which were not designed to hold weight. If you are going to stick with that tank, I woulsd put some straps on it.
I like the frame mods. Very nice work!
