Old 07-23-2007, 07:33 PM   #1
ksjh1316
ksjh1316's Avatar
Question Sounds like a time bomb
Just noticed today a ticking sound when the gear is engaged and the truck is moving. Out of gear there is no noise at all kind of hard to check this while moving down the road by myself. Engine is a 292 and not sure on trans other than 4 speed man any sugestions as to where to start looking is appreciated. Also I know in my British cars Slick 50 and other similar products were bad does the same hold true for these trucks.
ksjh1316 is offline   Reply With Quote
Old 07-23-2007, 07:48 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Sounds like a time bomb
I guess the first thing I would do is to check the transmission fluid. I'm not familiar with the truck 4 speeds but there should be a plug about halfway up on the side of the trans case. The gear lube should be up even with the bottom of the hole. Hopefully someone with a little 4 speed experience will chime in here....
Just happened to think that it might be a universal joint on the drive shaft too. They make a clicking noise when they are loose.
LockDoc
Leon
Old 07-23-2007, 07:48 PM   #3
nplocoman
never finish start another
nplocoman's Avatar
Does it tick when coasting in neutral?
nplocoman is offline   Reply With Quote
Old 07-23-2007, 07:58 PM   #4
ksjh1316
ksjh1316's Avatar
No she gets quiet again thats one of the pieces thats has me puzzled. I appreciate all help so far this just is frustrating.
Old 07-23-2007, 08:17 PM   #5
68gmsee
Active Member
68gmsee's Avatar
Since you mention it does it under load, I would suspect a bearing also.
It could be coming from a bearing in the transmission, driveshaft u joints or rear wheel bearings.
I'd start with the easiest like inspecting the u joints and then the wheel bearings.
68gmsee is offline   Reply With Quote
Old 07-23-2007, 08:38 PM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I was thinking Throw out bearing but if it does it under load but not in neutral then it's probably going to be one of the ones above.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 07-23-2007, 09:35 PM   #7
nplocoman
nplocoman's Avatar
Also check the carrier bearing. I had one that would squeek uynder load.
Old 07-23-2007, 10:51 PM   #8
wheels67
wheels67's Avatar
Im with this one. Had it happen to me before.
wheels67 is offline   Reply With Quote
