Old 07-23-2007, 09:31 PM   #1
76bonanza
76bonanza's Avatar
dash pads
two questions
Having a hard time finding a white dash pad or pad cover pure white not off white I know it was not factory.
second, has anyone used that top dash cover the LMC sells, covers the metal top pad of dash? (not sure if anyone else sells it.)
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 07-23-2007, 09:37 PM   #2
'68 longbed
'68 longbed's Avatar
Re: dash pads
the previous owner of my 68 put one of those covers on .....I don't know if it's typical but it clearly had a thin spot in it and the sun made it "bubble" as though someone put a lighter under it in that spot.
i'd say if you get one make sure it appears to be uniform in it's molding.
"spiiiider pig, spiiiiider pig, does whatever spiiiider pig does. "
'68 longbed is offline   Reply With Quote
Old 07-23-2007, 09:40 PM   #3
70c10
67-72 Addict!
70c10's Avatar
Re: dash pads
I like the dash caps!. They work well.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
