Old 07-24-2007, 12:51 AM   #1
70heavyhalf
finding new carburetor for inline 6
I need to replace the 1 barrel carburetor on my 250 inline(1970) and I was wondering were the best place would be to buy one. The only ones I find in summit for a pickup truck are for the years 1967 and 1972, but then they have a carburetor for a 1970 van, I would think these would work but just to be on the safe side.
thanks in advanced
70' 1/2 ton 2wd 350/muncie m-20/12-bolt rearend
Darin
70heavyhalf is offline   Reply With Quote
Old 07-24-2007, 12:56 AM   #2
AuggieStyle
AuggieStyle's Avatar
Re: finding new carburetor for inline 6
i have a 69 inline six so i am going to watch this topic, thanx
AuggieStyle is offline   Reply With Quote
Old 07-24-2007, 12:59 AM   #3
Brad
Out of the carpool lane.
Brad's Avatar
The '67 carb probably won't work as it's most likely a Rochester BV and you've probably got a Rochester MV. I would be inclined to try the '72 carb, however I think your best bet in your case would be to take it to your FLAPS and have them match it up. That way you're sure to get the correct carb.
Now if you're looking to upgrade and do all sorts of expensive mods on that little six, go get yourself a V8! Unless you're a diehard like me, it'll be cheaper in the long run.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 07-24-2007, 02:36 AM   #4
cell
Active Member
cell's Avatar
i imagine your best bet would be to try and find one on this board.
I have a 1967 single bbl carb on my truck if you need pictures or anything.
cell is offline   Reply With Quote
Old 07-24-2007, 02:38 AM   #5
cell
Active Member
cell's Avatar
by the way, make sure you get a carb which has a mixture adjustment. my carb does not appear to have a power circuit mixture adjustment (the only adjustment is for the idle circuit), and this carb is jetted permanently rich, which leads to problems like carbon buildup in the cylinders, fouled plugs, not to mention 11 MPG...
Old 07-24-2007, 05:35 AM   #6
I put a remanufactured/rebuilt one on my 70 from Auto Zone. It was around $100. I had no problems what so ever. The difference I saw between the carbs they listed at the time was the carb was either manual choke (like mine) or had the provision for the automatic choke.
Palf70Step is online now   Reply With Quote
Old 07-24-2007, 07:14 AM   #7
notahybrid
Just put one from Rock Auto on my 68 c10 250. The one I got was reman. by United Remanufacturing Inc. they are a wholeseller but gave me some great feedback prior to and after purchase. I paid $120 minus a $30 core charge for that Rochester M 1 bbl. I have had it installed about a month and so far so good.
notahybrid is offline   Reply With Quote
Old 07-24-2007, 07:33 AM   #8
truckdude239
truckdude239's Avatar
http://www.partsamerica.com/ProductL...for=Carburetor
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
