07-21-2007, 02:46 PM | #1 |
Van Tilt for Manual Trans or for Parts
The lower shifter arm was sawed off by a PO for a manual trans setup. Turn signal wiring has the correct plug spliced on it. Tilt seems nice and solid, use for parts or put in your floor shift truck. $40 plus shipping.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
07-21-2007, 03:03 PM | #2 |
Re: Van Tilt for Manual Trans or for Parts
interesed.. can i get a few more pics? can you post one of the shifter area??
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
07-21-2007, 04:01 PM | #3 |
I'm also interested pending pics. Thanks Jason
2007 Chevy 2500HD crew cab, 4x4, duramax w/Allison trans. 2001 Chevy ZR2 Ext. cab 4x4 (DD) 1967 Chevy SWB 4x4, BBC, Th400, NP205, 6" lift, and 35's (In Process) 1970 Chevy Blazer 4x4, BBC, TH400, NP241, 6" lift, and 38.5 boggers in front, 44 boggers on the rear ( mud racer project) Last edited by 4bynut; 07-21-2007 at 04:02 PM. |
07-21-2007, 04:58 PM | #4 |
I tried to get better pics, if you need a better close up pic of some area let me know.
07-21-2007, 05:29 PM | #5 |
is the upper shifter area been ground down?? or is intach??
thanks
07-22-2007, 12:37 AM | #6 |
please put me in line pending shipping thanks Mike
07-22-2007, 01:08 AM | #7 |
The shifter boss is still there and the pin is still in it, not ground off.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 Last edited by Green Machine; 07-22-2007 at 01:09 AM. |
07-22-2007, 01:41 AM | #8 |
can you give shipping quote to 47224 thanks...
07-22-2007, 01:44 PM | #9 |
PM sent to Jamie72
07-22-2007, 10:24 PM | #10 |
Ill take it if you would rather it be picked up. Not trying to jump ahead of line. Ill go to the end here...
07-22-2007, 11:17 PM | #11 |
Jamie72, best I can do $55 shipped.
Corn, thanks, no problem, if it gets down to ya its yours.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 Last edited by Green Machine; 07-22-2007 at 11:24 PM. |
07-23-2007, 06:20 PM | #12 |
Jamie72 passed - 4bynut you are next...Whats your zip ?
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 Last edited by Green Machine; 07-23-2007 at 06:23 PM. |
07-24-2007, 02:47 AM | #13 |
PM sent.
2007 Chevy 2500HD crew cab, 4x4, duramax w/Allison trans. 2001 Chevy ZR2 Ext. cab 4x4 (DD) 1967 Chevy SWB 4x4, BBC, Th400, NP205, 6" lift, and 35's (In Process) 1970 Chevy Blazer 4x4, BBC, TH400, NP241, 6" lift, and 38.5 boggers in front, 44 boggers on the rear ( mud racer project) |
07-24-2007, 02:24 PM | #14 |
4bynut - $55 shipped to your zip - PM sent with my address info.
07-25-2007, 04:32 AM | #15 |
Thanks, but I'm going to have to pass also. Good deal for someone. Sorry for any inconvienence. Jason
07-25-2007, 01:42 PM | #16 |
Living In The Past
I'll get in line
07-25-2007, 07:12 PM | #17 |
Down South Truckin you are next - $55 shipped.
07-26-2007, 04:45 AM | #18 |
put me in line it will keep me from cutting the one I have up.
Earl 68 2500 4x4 GMC Burb |
07-26-2007, 06:04 PM | #19 |
Corn - your're next...
07-26-2007, 07:37 PM | #20 |
Done! Ill PM to see when we can get together. Thanks Tom...
07-26-2007, 10:00 PM | #21 |
I'll pass but thanks anyway! D>S>T>
