Fabricate till you "puke"
5 lug ralley wheels?
I currently am running 15x6 1/2's up front, & 15x8's rear. Looking to widen the front shoes a touch, but will need 15x7 wheels to do so......what did they come on pickups, or vans?
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Re: 5 lug ralley wheels?
Trucks. They are available from aftermarket sources as well.
Im not having much luck on aftermarket, I keep finding 8's & 10's. The trucks must have had 7 & 8 " wheels depending on package? Im sure the 6 1/2 " ones are from a van, & thought the 8 " wheels were truck or burb? They are all over the boneyards around here, so I should be able to find a decent pair.....would like new if i could find em tho...
