i lost the key for my locking gas cap....
how should i get it off. it really didn't fit right in the sense that it didnt screw on, it just pressed on untill the "ears" of the locking mechanism engaged the lip of the fill tube. tia
'71 LWB 350/350 banana yellow '02 VW GTI turbo 14 sec. 1/4 mile |
LAIDOUT
Re: i lost the key for my locking gas cap....
Is it in the stock location and made of plastic? I'd say cut the head of it off with a sawsall, but if its a metal cap that may be a bad idea!
stock location and metal. i may be able to pry it off but dont want to damage the fill tube.
STOLEN
![]() Join Date: Jun 2006
locksmith.
In Search Of |
Official Site Guitar Shredder
i dont this about 2 years ago. i took an 1/8 inch drill and drilled out the key ways. then i took a 1/4 inch bit and re-drilled my 1/8 inch holes. then i took a straight head screw driver in the key ways and ,after some prying and manovering<spell? it came off. mine was a standard napa locking cap. and was double walled. if yours is not i wouldnt recommend drilling it out. im thinking pretty much all of them are double walled, beacause if i remember right, the lock cylinder doesnt just hang in the fill tube.... hope this may help. also you might want to try a large pair og channel locks and twist it off. i wouldnt think that it would damge the fill tube ,they are pretty stout, but what do i know..........tony
Insert Title Here
call the manufactur of the cap, or buy another one and hope the keys are generic
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
I also did this a couple years ago..... take a big screw driver, insert where key goes, drive screwdriver in with a hammer until it's tight, turn lock, remove cap. Worked great for me.... good luck.
71 GMC 1/2 ton 4x4, 350, 350th 67 chev short step, 396, 350th 41 chev flatbed, custom bed, frame & suspension, 350, 350th |
When I bought the 71,it had a locking gas cap and no keys..I just drilled it out and off it came...
20' Daredevil (Ret)
![]() Join Date: May 2003
I wonder how many different key patterns exist for those cap? Might be worth a trip to your friendly local parts store -- see if they'll let you try several keys. Might get lucky, especially if your lock is old and a bit worn.
Or just take it to a locksmith, or drill it out... ![]()
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
Junior Member
97guns,
I used to have one on the '81. My father ( retired ) borrowed the truck one day and needed to put gas in it. He did not remember that it had a locking cap even with the key on the ring ( and with his poor eyesight did not let him see the key slot - pre cataract surgery ). When he returned the truck, he did ask me why the cap was so hard to get off. He did say that he just got a good grip with both hands and twisted the cap right off - no tools involved ![]() I vote for just trying to twist the cap off and see what happens.
Have fun, Don |
This last winter mine was frozen on, and I was pretty much out of gas, so I HAD to get it off. I think I just took a screwdriver to it and pretty much pried it off. It was a big PIA and took about 15 minutes.
LAIDOUT
That's hiliarious! "Damn boy you need to work on that gas cap." Strong retired guy your dad!
Old Skool Club
![]() Join Date: Jun 2001
For what it's worth, the key to my locking gas cap (from NAPA) also works the ignition on my Cub Cadet. I put in an ignition switch from......NAPA.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Tot Roddin'
I had a lockable plastic gas cap on my F*** Explorer in High School, and you could squeeze, at both ends of the handle, towards the center of the cap and turn and it would be able to be removed.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#15 | |
MOVE OVER
sounds like my dad,, he's now legally blind (can see a little, but can no longer drive) but still strong as a ox!
No matter where you are..... There you are... Buckaroo Banzi |
#16 |
EZEKIEL 25:17
^^^ +1.....I had to do the same thing worked great.
68 CHEVELLE(HORSESHOE) 69 LONGHORN 396 70 NOVA 454(FOR SALE) 71 SWB 307 71 EL CAMINO 383 72 GMC JIMMY 350 87 BLAZER 350 WIW? http://blog.360.yahoo.com/blog-r5CJt...9_6Orzim4L5uWM Gun control, the theory that 110lb. women have the "right" to fistfight with 210lb. rapists. The reason animal rights activists are more passionate about fur than leather is because it's safer to harrass rich women than bikers... |
#17 |
Sourdough
Assuming the tank is in the factory location...
You could undo the hose clamp from the plastic filler tube extention that the cap locks on to and pull the cap and tube out of the truck then take a long blade screwdriver and just pulsh the locking tabs in. Worked amazingly well on my '70. Tim |
#18 | |
Junior Member
Have fun, Don |
#19 |
Just get some channel lock and clamp down and twist. Worked on my s10 and several other vehicles at the shop. I wish people would start leaving the gas keys when they come in for gas related things.
1970 Chevy C10 "Under Construction" ![]() 2002 Chevy S10 V6 ![]() |
#20 | ||
#21 |
I was in the used car business for several years and ran accross this many times--------jam a blade type screwdriver in the lock and it will turn right off----did this many dozens of times.
#22 |
Licensed to Thrill!
IIOY?
![]() DLB |
#23 |
thanks everyone - the big screwdriver did the trick
#24 |
I bought a master lock kit off the MAC Tool truck. it has a couple of picks for locking gas caps. They work to. took about 2 seconds and it poped right off. ANd guess what it didn't destroy the cap either so when you did find the key.Also unlocked several cars with it. saved me the money of calling a lock smith.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
#25 |
chrome makes it go FASTER!
I would not recommend getting out the torches.
She can't cook and she won't clean. But she looks good in a skirt and she brings me beer. She can stay for now. EDIT:: But she left me anyway, So forget her. 1962 GMC Stepside V6 4 speed My rolling resto thread http://67-72chevytrucks.com/vboard/s...d.php?t=324226 My old farm truck http://67-72chevytrucks.com/vboard/s...=1#post3465005 |
