#26 |
Re: Looking for pictures of swb with air ride
So if you install a bolt on c notch from Air Ride. You have to cut your bed? Could someone clairify this for me. Thanks
#27 |
Real Projects never die
you cut your frame for a C notch
Ill put it this way, ive got a few lawn ornaments ![]() ![]() My name tag says Ryan KansasTwister On other forums
#28 |
Sophomore Member
![]() Join Date: Jul 2006
i know you were wanting short trucks, but mine has a c-notch only and has a wood floor bed. it has dropped spindles with the bags up front and 2 inch blocks as well as bags in the rear. if you air out the rear completely, the pumpkin will touch the bed floor. hope this helps. last pic is at ride height.
1972 Chevrolet Highlander SWB 1972 Custom Deluxe 3/4 2WD 60k miles these trucks don't need vacuum gauges cause they don't suck! two wrongs don't make a right, but three rights do make a left all i want is a little more than i'll ever get it's better to be judged by 12 than to be carried by 6 |
#29 |
![]() Join Date: Dec 1999
Here is my sons truck!
#30 |
That's right, it's Copper!!
Tim, who makes the bed cover on your sons truck.
#31 |
It is made by Checker Products in Benton, KY.
#32 |
Parts and more parts
This one is a local truck that made it to the front page opf Custom Classic Trucks. It has an Air Ride suspension.
#33 |
Epoxy Primer Friendly
My ongoing Project..... on the door with 22"s
#34 |
WTB this ad
Anyone ever thought of "shaving" the top of their diff for bed floor clearance on these milder setups? And when I say milder I mean the guys wanting all the drop they can get without the diff coming through or impacting the bed floor. The 4x4 guys have been doing this to the bottom side of diffs for some time now for the extra ground clearance.
