My engine "misses" under load. For example, when I shift from high rpm 3rd gear to low rpm 4th gear, it usually misses, sometimes a series of "misses." Or 3rd gear going up a hill at lower speeds.
Got a recently rebuilt 350 with newer edelbrock performer intake, newer edelbrock 600 cfm carb with electric choke, newer summit HEI. Any ideas on what might be causing this? Thanks, Chris
RLTW 70C10 72K10 72K10 Cheyenne 72C10 Cheyenne Super |
Jostrans68
I had similar problem found the valves were a shade to tight re adjusted and it went away
![]() former 67-72 now with a 96 silverado |
Used to have a truck
too cold a range of plugs will do that too. What are you using for plugs? Ive been using AC 43 TS's gapped at .055" after a similar problem with a colder range plug that had occasional miss problems.
No truck :-( |
My other Love
Id check your timing. Might be a bit retarded. Try re gapping your plugs, maybe make the gap a bit wider. Your truck could also be a bit cold. Is your choke working properly?
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
Thanks for the replies - some good advice. I checked the timing, it's dead on. The problem is a new one, so I'm inclined to think that it might not be the valves. I'll check the plugs, though, appreciate the tip on the hotter plugs.
Could it be fuel? I thought that maybe my fuel pump was going south. Choke could be it, but it's a fairly new Edelbrock with electric choke. Thanks, Chris
