11-21-2004, 03:52 AM | #1 |
Senoir Member
Big Block P/S Reservoir Hose???
What is the best type hose to use for the remote reservoir on the big block? I used a 3/4" heater hose, and after about 1 year the fluid has started seeping thru all over. Any ideas?? Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4" 70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010 70 GMC Restoration Pictures http://67-72chevytrucks.com/gallery/...00&ppuser=4424 |
11-21-2004, 04:35 AM | #2 |
"Do Not" use heater hose for any kind of petroleum products. It deteriorates after a period of time, and is almost as bad as using a garden hose. Try and find some "Push-Lok" hose. Works great for about any kind of hoses you'll find on a truck. Hope this helps?
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. |
11-21-2004, 08:15 AM | #3 |
Watch out for your cornhole !
Look in the phone book under "hose" shops, or "hydraulic" shops. They will have the hose you need.
11-21-2004, 10:44 AM | #4 |
Gates offers pw steering hose that is correct for you bb. You need to find a parts person willing to look for you but it is listed in the gates catalog. I got mine when I worked in parts store.
11-23-2004, 01:27 AM | #5 |
Senoir Member
Thanks guys, I had no idea the heater hose would leak through. SURPRISE!!!
11-23-2004, 06:52 AM | #6 |
I used a short piece of clear vinyl tubing; has worked fine for last 10 years....and a side benefit; a quick glance will tell if there is adequate fluid in the reservoir. The temperature has not been factor as far as long life...Normal temp range for flexible vinyl tubing is -25 to 140 degrees F.
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
07-30-2007, 02:19 AM | #7 |
Senoir Member
Re: Big Block P/S Reservoir Hose???
Finally got around to fixing this. Gates has a 3/4" hose similar to heater hose that is rated for transmission fluid. It is listed as Gates # 349990 power steering return hose, it's 10 feet long in a box. I had to order it, but it's the right hose.....cost about $10 total.
