radiator/trans cooler ????
Looking for more imput. Changing motor and notice a small leak in factory radiator. Looking to swap with aluminum. I have been told to go with a plain radiator and add a trans cooler. Also adding a/c and will have that to mount up front somewhere. Any advise and or comment would be most helpful. Pics would be even better. Is changing to aluminum a good thought or bad?
Thanks Gary |
Re: radiator/trans cooler ????
I changed to an aluminum and love it. I got a Griffin, which is a little pricier, but I will never have to worry about overheating in traffic again. It bolted right in with the exception that I had to get the cradles for a 4 core radiator which is a little bigger than the 3 core cradles I had.
Hope this helps. Ronnie
1968 C10 Stepside 396 bored .030 TH400 |
For the trans cooler, bigger is better. Personally, I'd go with one built in the radiator & add an add'l cooler.
Only thing is, if you live in cold weather, you might now want too much trans cooler, especially if its your only cooler.
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! ![]() 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! ![]() |
if used in cold weather its better to have an integral cooler and radiator setup
