Old 07-29-2007, 03:32 PM   #1
1Ton
1Ton's Avatar
Replacing brake lines
I need to replace all the brake lines on my project Rusty (84 K30)
Where do you guys suggest to order a kit for oem replacement lines?
TIA
Support your local search and rescue team.... GET LOST!
Originally Posted by DURRTY
if some is good
more is better
too much ought to be enough........
1Ton is offline   Reply With Quote
Old 07-29-2007, 06:47 PM   #2
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
Re: Replacing brake lines
when i did my break line on my old 86 i just went and got straight line from autozone that was coated to not rust. i then proseted to remove the old line and use a pipe bender so make it the same as stock and it was cheaper to.
JUst a thought and the tool you cna rent or buy at the zone. (autozone) its cheap and comes in handy alot
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 07-29-2007, 09:38 PM   #3
1Ton
1Ton's Avatar
Well LMC truck has a set for $99 and I replaced one line on a truck and by the time I bought the fittings to join the two lines I had $35 into it so I was thinking. I would have more in lines and fittings than a prebent kit.
if some is good
more is better
Old 07-29-2007, 10:24 PM   #4
Srubydo1986
The Crazy Machanic
true but i just did all of it and only had i think 2-3 fitting for the main stratch.
newest additions
Old 07-30-2007, 03:25 AM   #5
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
My front brakes setup - stock master cylinder nut, new parts-store-special 3/16 brake line ($3), a T-ee union ($2), two more parts-store-special lines (short piece for left side ($2), loooong one for the right side ($4)), and that's all.
My rear brakes setup - stock master cylinder nut, short 1/4 part-store brake line ($2), manual brake bias valve ($25), four looong pieces of parts-store brake line ($4 each), three 1/4 unions ($1 each), and that's it.
Total for the fronts - under $15, total for the rears - under $50. Best of all I bypass the stock proportioning valve (I use different tires front and back so it's off) and I get to adjust the rear brakes as I please - half off when running empty, increasing the pressure as the load goes up, all the way to full pressure if there's something big behind me that I have to stop
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
Old 07-30-2007, 04:26 AM   #6
1Ton
1Ton's Avatar
Well maybe I'll just go the piece it togethor route.
if some is good
more is better
Old 07-30-2007, 07:38 AM   #7
beaterC10
You might try Inline Tube or Classic Tube for pre-bent lines. I used one of these places for the pre-bent lines for the rear axle on my 1/2 ton. The pair of lines was around $30. For me the convenience was worth the extra money I spent.
beaterC10 is offline   Reply With Quote
Old 07-30-2007, 01:43 PM   #8
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Originally Posted by beaterC10 View Post
You might try Inline Tube or Classis Tube for pre-bent lines.
This is where I get mine (either of the 2) as I wanted the stainless versions.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
