Old 07-29-2007, 09:36 PM   #1
70' GMC
HERE.......Somewhere
70' GMC's Avatar
Question Needle???
my mph needle when it goes from 0 to 30 the needle shakes makes kinda like click clack sound
Current rides: 2013 Hyundai elantra gt DD
1995 camaro my first crush lmao
Was: 1970 with a 350 4barrel and 288 horses
Classics make it possible!
70' GMC is offline   Reply With Quote
Old 07-29-2007, 09:56 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Needle???
the speedo cable needs cleaned, and then lubed with graphite.
Old 07-29-2007, 10:07 PM   #3
Texasbigblock
Texasbigblock's Avatar
Re: Needle???
mine used to do that, i took out the inner cable, coated it with white lithium grease and slid it back in. Worked great!
-Scott-
1970 C10 shortbed 396
1969 C30 dually flatbed "Vidalia"
Texasbigblock is offline   Reply With Quote
Old 07-29-2007, 10:45 PM   #4
Longhorn Man
Re: Needle???
I wouldn't use any kind of grease
Old 07-29-2007, 10:48 PM   #5
Texasbigblock
Re: Needle???
why not use grease? White lithium grease resists all moisture and probably will never dissolve or age.
-Scott-
Old 07-29-2007, 11:25 PM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Needle???
While I think Andy's right about using graphite, I didn't know about that when I lubed my cable with white lithium grease many, many years ago. It's still working fine.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 07-30-2007, 10:56 AM   #7
airdale94
airdale94's Avatar
Re: Needle???
I used to use gear oil.
airdale94 is offline   Reply With Quote
Old 07-30-2007, 10:33 PM   #8
70' GMC
70' GMC's Avatar
Re: Needle???
could I get directions with pictures????
Old 07-30-2007, 11:45 PM   #9
68gmsee
Active Member
68gmsee's Avatar
Re: Needle???
I think the reason that they don't recommend grease, is that in dusty environments dirt tends to stick to the cable. Here in Texas we have a lot of caliche (limestone), gravel and dirt roads that are extremely dusty when dry. If you use any kind of grease or oil they get pretty nasty looking.
I'd say if its mostly city driving, lithium lube or a lite oil would be okay.
68gmsee is offline   Reply With Quote
Old 07-30-2007, 11:50 PM   #10
68gmsee
Active Member
68gmsee's Avatar
Re: Needle???
You should be able to just reach behind the instrument panel where the cable connects and disconnect it from there. Pull the cable out from the sheath with a pair of needle nose or duckbills.
After cleaning and lubing (or graphiting) slide it back in until it's all the way in.
Old 07-30-2007, 11:54 PM   #11
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: Needle???
so you can just pull it out from the speedo end and put back in the same way and thats it???
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 07-31-2007, 12:04 AM   #12
cdowns
cdowns's Avatar
Re: Needle???
the grease causes drag and over the years the accumulation of the metal residue cloggs the cable // thats why the manufacturers came up with the speedo cable lube as it polishs the inside of the housing for a friction free turning of the cable
Old 07-31-2007, 08:26 AM   #13
68gmsee
Active Member
68gmsee's Avatar
Re: Needle???
That's what I've done on mine. The cable has squared off ends that fit into corresponding holes in the speedometer and the transmission gear.
Now if your casing looks dirty and you want to do a complete clean and lube then I would disonnect from trans end also and remove the whole cable and casing.
