Old 12-18-2002, 03:24 PM   #1
smithjp1
smithjp1's Avatar
Lift Kit Suggestions
I have 68' swb chevy 4x4, doing my restoration, it looks like there is 4 inch lift blocks under the stock leaf springs. Give me some adivse
Should I re-arc my springs and put the lift blocks back
$25 per leaf = $100
Should I add new thicker leaf springs that will give me 4 inches
how much and where??
Thanks.
smithjp1 is offline   Reply With Quote
Old 12-18-2002, 03:34 PM   #2
694X4
694X4's Avatar
I just bought a 6" sky jacker kit for $518.00 and it came with blocks for the rear, spings for the front, shocks, shock boots, and a raised steering arm. Going cheap and getting the blocks for the rear was a bad idea and now I had a set of springs made for the rear 6" taller for $200.00. If you have blocks under the front springs it IS NOT SAFE TO DRIVE ON THE STREET!!!!!!!!!!! Make sure the front is all spring lift. I have seen front blocks kick out going down the road and it is not pretty at all.
69 3/4 ton 4x4 gmc with 6" sky jacker soft ride. 350 / th350 / 205
work in progress
694X4 is offline   Reply With Quote
Old 12-18-2002, 03:37 PM   #3
smithjp1
smithjp1's Avatar
I will take your advise on that one
Blocks are coming out the front ASAP
Old 12-18-2002, 04:50 PM   #4
Mudder
Mudder's Avatar
Totally agree with blocks in the front!! Takem out!
Mudder is offline   Reply With Quote
