Old 12-18-2002, 06:55 PM   #1
RED72blazer
urban fourwheelin
RED72blazer's Avatar
Thumbs down Oh crap!!!!!!!!!!My truck is molding
what should I do It's everywhere. are there any moisture trapping techniques I could you until I get this thing running again?
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 12-18-2002, 07:33 PM   #2
crazy longhorn
Fabricate till you "puke"
my truck is inside, but not a heated garage. I use card board or carpet under the truck to suck up the humidity, & have heard that if you leave the windows cracked you wont have problems with the interior........must be something to it, I havent got the door glass back in after chopping the top, & dont have any trouble with the inside getting "groaty".........
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-18-2002, 07:39 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Its a blazer thing i guess cause mine also does it ,but it also leaks like a sive when it rains......
LUKE
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 12-18-2002, 09:36 PM   #4
LeRoy
Registered truck nut
LeRoy's Avatar
Go to your local RV store or Wallmart and pick up some humidity catchers. They're a little bucket type device that you add some crystals to. Or just put an electric heater in it when stored. Don't forget to unplug it when your leave, lol
MOUNT VERNON, WASH. STATE
Need a part? Just PM me
LeRoy is offline   Reply With Quote
Old 12-18-2002, 09:44 PM   #5
Southpa
Southpa's Avatar
I second leRoy on that. Also, if your seat cover and carpet are molding out on you, remove them from the truck and store in a dry place. Mold growing on vinyl and other areas? Wipe down with a mild bleach solution.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 12-18-2002, 10:42 PM   #6
RED72blazer
urban fourwheelin
thanks guys, Thats kinda what I was thinkin. i'll go look for the moisture catchers tommarrow and wash it with bleach solution.
thanks again
soaking wet Red72blazer
Old 12-19-2002, 01:45 AM   #7
Hooter
My other Love
Hooter's Avatar
whats weird is that my monte sat outside since 1993 and It never molded. But my 77 sat one winter and it molded. Its weird. its a good thing you don't have moss growing on your truck though
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 12-19-2002, 02:05 AM   #8
oldiron
Designated Grumpy Old Man
oldiron's Avatar
I had a moisture problem in my shop. My tools were rusting, had mold growing on the walls and a lake on the floor. Broke down and bought a dehumifier from grainger. I removes 4 gallons of water a day from the shop after putting it on a timer for 8 hours a day and the mold has disappered, the tools don't rust and my lake is gone. Best money I have spent on preserving my trucks and tools.
oldiron is offline   Reply With Quote
Old 12-19-2002, 03:13 AM   #9
Reumster
L.E.D. Freak
Reumster's Avatar
Oh well just put it to use and grow Shrooms! LOL
Specializing in Custom L.E.D. inserts.
http://www.ccled.com/
Contact me @ blazer2wd1972@hotmail.com
(406)675-8082
or Joel @ jmcwaters@eps-corp.net
1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL
Reumster is offline   Reply With Quote
Old 12-19-2002, 05:10 AM   #10
Lippyp
English Chevy Owner
Lippyp's Avatar
I would definitely go with the moisture traps if your truck is outside and you need to keep the windows closed. I have used them on various cars over the years and whilst they may not stop the problem entirely they do make a difference. Just be careful with the water that collects because the crystals dissolve into it as they trap the moisture and it becomes corrosive (Alkaline) so don't let it get too full before you have to move it to empty it. If you truck is in a secure garage leave the windows open, nothing works better than airflow!
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 12-19-2002, 05:11 AM   #11
Lippyp
English Chevy Owner
Lippyp's Avatar
I would definitely go with the moisture traps if your truck is outside and you need to keep the windows closed. I have used them on various cars over the years and whilst they may not stop the problem entirely they do make a difference. Just be careful with the water that collects because the crystals dissolve into it as they trap the moisture and it becomes corrosive (Alkaline) so don't let it get too full before you have to move it to empty it. If you truck is in a secure garage leave the windows open, nothing works better than airflow! (the moisture traps work best in a sealed environment so probably won't help much with the windows open as you will be trying to dehumidify your entire garage!)
Phil
'67 C10 long fleet.
Old 12-19-2002, 06:08 AM   #12
Lightspeed
put some baking soda on a paper plate and leave it in your floorboard. and get a dehumidifier.
Lightspeed is offline   Reply With Quote
Old 12-19-2002, 10:54 PM   #13
Dads72
This sounds strange, but it really works.
Have a vehicle I have stored under a car cover for the last 3 winters.
Get a pan/tub/whatever and fill it with scented kitty litter.
It soaks up the moisture and the vehicle smells like new.
(plus it freaks out the mice)
Dads72 is offline   Reply With Quote
