When searching for my oil leak I found a sensor or something on my engine.
It is located on the driver side and screws into the block. Its right in front of the oil filter. It has about 3-5 wires coming off of it and heading up towards the distr. I didnt follow them all the way, but they head that direction. They may be going into my wire harness. Anyone know what this may be?
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
driving is in my blood
knock sensor for the ESC distributor? Do you have a HEI?
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
I replaced my original distr. with a Proform HEI. The Proform doesn't hook to the computer like the original.
Is that the normal location for a knock sensor? Because I thought I already removed or disconnected my knock sensor on the passenger side of the block. Ohh well I guess I'll just track down the wires and see where they go. What ever it is will most likely be removed.
You get what you pay for
![]() Join Date: Dec 1999
On my 85, and I'm sure on the rest of the LE9 engines, the knock sensor is on the passenger side front of the block. On some engines they had oil pressure senders in front of the oil filter, but it sure wouldn't have 3-5 wires going to it. I'm not sure when they quit putting the oil pressure sender in front of the oil filter. Also, the knock sensor don't have 3-5 wires either.
Mike 1985 Chevy C-10 |
Damn what the hell is it then. Ill let you guys know what it is when I figure it out.
pkbinplano
un plug it and see what happens !
http://www.picturetrail.com/gallery/...7496&members=1 84 chevy silverado aka The Bananna Boat |
Gentleman Jim Driver
That is right above the oil filter. It is an oil pressure switch that stops voltage from going to your electric choke. It is why the choke light comes on when your engine dies. If you don't have oil pressure but continue to drive your truck, it will keep it from running well (choke will take forever to come off) and maybe make you look down at your gages to see that you have no oil pressure.
I found this out the hard way when I replaced an engine and didn't put that switch in. I couldn't figure out why my choke worked before, but not after the swap. I ended up jumpering the connector, it's worked that way for four years!
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
My other Love
My unlce had that same type of switch on his boat. Turns out this switch would cut the motor off when there was no oil pressure. Th 4.3 would never start took me 3 hours to track that thing down
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
Whats this wire for?....
you should ask your mom.....
Just kiddin' ya! ![]() Im not sure, I just wanted to keep you post at the top so you get a good answer. sorry I can't help. I don't have that sensor, I looked after I read the post. L888's
Kyle ![]() '82 C10 Resto-Custom--> * 2 1/4" manifold back dual exhaust with Hooker Aerochambers & High Flow Cats *Taylor Ignition Wires *Centerline 15" Telstars with 32"x10" mudders |
