JNZ Finishing LLC.
"1511" 400 w/ new rebuild parts
Over the winter, I picked up a complete 1511, 4bolt block 400 for my 72 w/ 650cfm Edelbrock carb, Edelbrock intake and 64cc heads. I stripped everything down to the bare block and made sure it was good for a rebuild. Since early spring its been sitting waiting to go to the machine shop. Now that I've decided to sell my 72 project, this motor has to go as well. I bought the following rebuild parts and they're still in their boxes:
Push rods Off-road needle and seat of carb Rebuild kit for carb Full bearing set Full gasket kit Oil pump Speed-Pro pistons w/ .020 over rings Roller tip rockers Lifters Summit 252/262 flat tappet cam True Roller timing set 5.7" rods HEI distributor Fuel pump So for the block, crank, heads, intake, carb and all the extras I listed, I'd like to get 800$ picked up in the Philly area. I don't want to part everything out, that would take too long so it all has to go at once. Everything is located in Hatfield, 19440.
JNZ FINISHING LLC.- PM me about our POWDERCOATING & CERAMIC services 67 K10 shortbed....6"lift, 35s, 350/350/208 |
JNZ Finishing LLC.
Re: "1511" 400 w/ new rebuild parts
Would anyone be interested in just the block, crank, heads and intake???
Wez
Just back from Utah, saw your post, have a buddy who has been kicking around the 400 deal. Let me get up with him tomorrow and I'll drop you a PM after. LILREDGMC |
I would jump all over that if i lived closer shipping would kill me
71 Chevy C/10 lwb 350 5 speed nv3500 3.73 rear end 2.5" Front Drop and 4" in the back Edelbrock perfomer rpm manifold Edelbrock 600 cfm carb Headmen headers |
what kinda rods does it have in it? thanks. chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. ![]() ![]() 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
JNZ Finishing LLC.
I believe they're made by Eagle, just a stock replacement that I picked up from Ebay. Eagle makes nice Hbeam race rods so I'm sure these are just as good for a stock replacement.
