08-03-2007, 04:35 PM | #1 |
No passing gear?
I have a 1980 Stepside with a th400 and 454. I see no kickdown cable - does it work by vacuum? Because there is a vacuum line going to the tranny. The engine combo is from another truck, and the swap was not done by me.
I assume there should be a a passing gear? Right? any ideas? |
08-03-2007, 10:24 PM | #2 |
Re: No passing gear?
It is electric on a turbo 400.
There should be a switch for passing gear. On a 1980 I believe the switch is down by the gas pedal. |
08-06-2007, 10:31 PM | #3 |
Might be a switch on the carb end of the linkage if it's from another type of vehicle.
08-07-2007, 07:59 AM | #4 |
The Crazy Machanic
might be a manual kick down meaning you shift down instead. like my chevelle had a th350 with a manual valve body, no kick down cables.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day) * 1970 chevelle 2dr sedan Latest update June 24 2007. *1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad) newest additions 1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in and a 79 c60 trash truck um no idea i have one |
08-07-2007, 09:42 AM | #5 |
I picked up a lockar kit from Summit Racing.
