Old 07-17-2007, 02:09 PM   #51
CrashBob
CrashBob's Avatar
Re: Project OverKill
Originally Posted by ChevyDude View Post
The drivers wheel and the alignment need attention for sure I took a 3 lb hammer to the steering box to get it removed. No worries....gots a 71' disc front ready to install after the frame shortening and the sandblaster!!!!
What kind of shape is the box in? I need a left long bed side. Interested in selling?
Crash
CrashBob is offline   Reply With Quote
Old 07-18-2007, 12:18 PM   #52
ChevyDude
Ready for the cab removal. Gonna pull the cab with my engine hoist. I started grinding on the firewall removing the small amount surface rust. Firewall to be shaved.
Now to get to real work, lol.
Alex
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 07-19-2007, 12:26 AM   #53
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Originally Posted by lowrollin70gmc View Post
You will now thank the state of ND for not using salt on their roads.
Some areas of the state salt, some don't. North Dakota spends $750,000 per year on rock salt per state transportation director Francis Ziegler earlier this year.
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 07-21-2007, 03:55 PM   #54
ChevyDude
Unbolted the cab. Picked it up off the frame and moved it back while I make some room for it in my shop.
Alex
Old 07-21-2007, 05:59 PM   #55
That is the nice part of a LWB, you got enough room to slide her back good.
Disassembly going good!
Old 07-25-2007, 12:48 PM   #56
ChevyDude
Had a little time this morning so I attached a 2x4 to my cherry picker and gently lifted the cab off the frame and put it on a pair of 55 gallon drums. Getting closer to the actual shortening of the frame.
Alex
Alex
Old 07-26-2007, 06:21 PM   #57
ChevyDude
A new ''big-time" shop tool arrives, new Miller 180 !!! Although I know nothing of welding today, I am determined to figure it out. I have wanted a welder for years and just never stepped up and bought one. Done it now! Lots of reading and practice...and then I will shave the firewall.
Alex
Alex
Old 07-26-2007, 08:49 PM   #58
Stepside65
Still Truckless!
Stepside65's Avatar
Lookin good. Wish mine could be in that good of shape... Keep up the good work man. Looking forward to seeing where this build goes.
~James
Truckless
2009 Hyundai Sonata<~~Wife's sedanomatic
1997 Nissan Pickup Father-in-law's tonka toy I am forced to drive
Founder of The 60-66 Club
Tutor Et Ultor
Stepside65 is offline   Reply With Quote
Old 07-26-2007, 09:53 PM   #59
Alex
Lesson 1 - Do Not weld (on purpose or by accidental spatter) your hair or body parts. Trust me, you do not want to know or do it
Get a good auto dimming helmet, good gloves, and lots of patience. It's fun to learn.
Old 07-31-2007, 09:48 AM   #60
ChevyDude
I do have an auto dimming helmet and a nice set of gloves, very important!
Little progress. Got the firewall down to bare metal, ready to start shaving all the holes. Mr. Miller 180 will be asked to lend a hand doing this....I have to practice first on some scrap like gauged material, that's for sure, don't want any burn through!!! I will be Epoxy priming the bare metal with SPI Epoxy primer.
Just got off the phone with SPI's Barry and his warehouse partner Terry...and the SPI epoxy is on the way!!!
www.BakerPBE.com
Alex
Alex
Old 07-31-2007, 04:42 PM   #61
Yukon Jack
Yukon Jack's Avatar
Good luck learning with the welder. I, too, want to learn to weld! Just need some free time.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 08-01-2007, 06:48 PM   #62
ChevyDude
Thanks Yukon!!! I am very excited about learning!!! As things work out , it looks as if Glock is going to come down to my shop and do the frame shortening here. He's going to bring his Plasma cutter and use my new Miller 180. I will be watching closely, with a auto darkening helmet on of course!!!
Little more done today. Removed front long bed brackets which are not needed for the short bed, and removed the passenger side rear cab support bracket. This bracket will need to be moved 12" towards the rear. And in true OverKill fashion ground a little on the frame to clean it up, love that clean metal!
Got the drivers side done too....today, Thursday 8/2/07.
Alex
Alex
Old 08-03-2007, 05:03 PM   #63
ChevyDude
FED EX just delivered the SPI Epoxy. Gotta get the welder going. Waiting on the pre cut insert pieces I bought on ebay. Last pic...pre cutting the rear of the frame. Glock reccomends cutting only 6" first as it's easier to cut more than add on. So going to cut the rear of the frame in a min here.
Alex
Old 08-03-2007, 05:15 PM   #64
68 short step
keep the progress pics coming
68 short step is offline   Reply With Quote
Old 08-03-2007, 05:46 PM   #65
ChevyDude
yep!!! Rear frame shortened 6"!!!
Alex
Old 08-07-2007, 10:10 AM   #66
ChevyDude
OK...the frame is now ready for the Glocks Plasma Cutter! Brake/fuel lines removed, bellhousing out, E brake cable gone. I loosened all the bolts for removing the front crossmember as I have a newly rebuilt (MOOG) 71' disc front that will go on after shortening the frame and sandblasting. That's the lastest. Front crossmember, springs, upper and lower A arms are available if someone needs them???
Alex
Alex
Old 08-07-2007, 11:56 AM   #67
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Alex - Just curious, did you happen to find where the VIN is stamped on the top of the frame under the cab?
One thing you might want to do is to tighten a few bolts on each side of that crossmember until we are finished. It would give me a warm fuzzy to have that end of the frame solid until we are done cutting and moving stuff around. Everything else looks good to go! I think we should be able to knock it out by the end of the month.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 08-07-2007, 11:56 AM   #68
faribran
want to part with the original hubcaps?
faribran is offline   Reply With Quote
Old 08-09-2007, 09:47 AM   #69
ChevyDude
YES Bob, I found the stamp! Not to worry, I re-tightened two bolts on either side after breaking them loose.
Hup caps are gonzo, sorry.
Cleaned up the outside of the frame in prep for the "shortening". I'll get the insides of the frame rail all cleaned up too!!! Clean metal, Glock's fine welding skills, a soon to be, SWB frame...another piece to the puzzle! ....And completed the wiring for the Miller 180. Nema 220 volt 6-50 Receptical. Made up a 10 gauge 40 ft extention cord with the same 6-50 Nema plug and receptical. Should have plenty of room , space, and cord to do all the welding and cutting needed!!! Makin' progress!
Alex
Alex
Old 08-14-2007, 07:16 PM   #70
Stoney
Farm Truck
Stoney's Avatar
Project Overkill is looking good.
1969 CST/10
1984 K5 Blazer 4x4
2016 Dodge Ram 2500 4x4
Mike
Jersey Village, Tx
Stoney is offline   Reply With Quote
Old 08-15-2007, 11:02 AM   #71
ChevyDude
Thanks Stoney. The shortening of the frame is next on the list. Glock is going to be doing the cutting and welding as my welding skills...ahhh, have not been developed ...YET! Glock should be coming down here to my shop to do the job some time before the end of the month. I am looking foward to this next step!!!
Alex
Alex
Old 08-15-2007, 11:39 AM   #72
glock35ipsc
Alex - The power options look great!! As soon as the in-laws get back, I'll have a better idea of when we can proceed.
Bob
Old 08-15-2007, 11:57 AM   #73
ChevyDude
Sounds great!!!
Alex
Old 08-15-2007, 12:48 PM   #74
Frizzle Fry
Frizzle Fry's Avatar
Cut-Cut-Cut
Frizzle Fry is offline   Reply With Quote
Old 08-15-2007, 05:54 PM   #75
ChevyDude
P-l-a-s-m-a
Alex
