Old 08-04-2007, 08:03 AM   #1
smoked68
smoked68's Avatar
Turn signal canceller
Hello guys, I just replaced the turn sig. cam, but am still having the same problem. The old one was the factory one and had a crack. The new one went in with no probs but will not cancel on the right turn. The left turn clicks off as should when wheels go strait. What else could be going on here. Also as a side bar the super charger came in this past Wed. it will find its new home in a few weeks. Thank you and all have a grand weekend. M
1968 chevy shortbed, Dark Shadow Gray
4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom
smoked68 is offline   Reply With Quote
Old 08-04-2007, 09:24 AM   #2
byrd
Union Electrician
byrd's Avatar
Re: Turn signal canceller
Are you sure the return spring is in there? Should be one for each side, a small round circle spring that cancels the trun signals.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 08-04-2007, 09:59 AM   #3
hgs_notes
GEARHEAD
hgs_notes's Avatar
You can get those little springs at most parts stores.
hgs_notes is offline   Reply With Quote
Old 08-04-2007, 11:36 AM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Ditto on the return cancel springs.
For some reason, my left spring always breaks shortly after installing a new one. I finally just gave up and manually cancel after left turns. Everything looks normal to me, obviously I'm missing something...
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 08-04-2007, 01:19 PM   #5
bad6772
Official Site Guitar Shredder
bad6772's Avatar
+ 1 i would check those first, and i think you can buy them separate from a dealership. i think when i baught mine they called it a service kit?
bad6772 is offline   Reply With Quote
Old 08-04-2007, 03:10 PM   #6
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
I had a similar problem. I went to Autozone and bought one of the turn signal repair kits in the "HELP" section. I installed the new cam and the new springs, and it wouldn't cancel either one. I put the old one back in with the new springs, and now it only cancels the left turn, the right one only works every once in awhile. Probably because it's a cheap foreign part, need to find some GM ones I guess.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 08-04-2007, 04:33 PM   #7
smoked68
smoked68's Avatar
Thanks for the info guys, I will try this asap. Its been doing this for a while, we got around to doing the cam with high hopes and it was the same, just no longer sloppy. I appreciate the help. Mike..........
Old 08-04-2007, 05:01 PM   #8
loef
loef's Avatar
I had also a problem with the new one.
But with cutting a bit away from the back side of the oval hole where the spring is mounted it was solved.
loef is offline   Reply With Quote
Old 08-04-2007, 05:57 PM   #9
72 68 andmore
I bought the whole kit new also and then had that problem still, so I took the springs from the old one and then it worked. The plastic was cracked that is why I replaced it. I call the place I bought it they refunded me for 2 springs and mentioned they had some issues with then and where sending springs to customers and changing vendors or notifying them or something like that
72 68 andmore is offline   Reply With Quote
Old 08-04-2007, 06:08 PM   #10
chipflyer
chipflyer's Avatar
I've got the exact same issue as smoked68, I have new parts including springs but it still cancels Left turns only. loef can you edit your photo and circle the area you changed? I am not sure I uderstand what you did.
thanks
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 08-06-2007, 03:35 PM   #11
smoked68
smoked68's Avatar
Again, Gentlemen you are a wealth of information, THANK YOU one and all. The pic will be a big help. It's always something. Thanks guys. Mike.....
Old 08-07-2007, 05:26 PM   #12
loef
loef's Avatar
On this one its better to see.
