Got Light Emitting Diode?
so i have changed my fan in the past so i know you have to pull the hood hindge to get that out, but do you have to pull the inner fender to get the heater core box off to get at the heater core? all tips and suggestions welcome.
68 chevy with no A/C thanks for any info Ben
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
Re: heater core question
I had to drop the inner fender to get the bottom screw out. I didn't put the screw back in so that I won't have to drop the fender again.
1968 C10 Stepside 396 bored .030 TH400 |
Active Member
Sure makes it a lot easier. I didn't have to totally remove the inner fender, just take out several bolts on the back side, and pry it down just enough to get heater box out. And I'm same setup as you 68 w/o AC.
its all about the +6 inches
There's a FAQ with a step by step for this.
sorry, didnt have time to search when i posted this.
http://67-72chevytrucks.com/vboard/s...ad.php?t=69812 pretty much what i thought just was hopeing there was an easier way
