#26 |
Re: Lowered Pictures - Inspiration Needed!
Hey 79chevylover which leafs did you remove? I Wanna Know aswell
#27 |
I have 2,5" dropped spindles with 1,5" drop coils in front and a flipkit out back.
I removed 2 leaves wich didnīt affect on the drop but should ride smoother! Tires are 265/50/15 in front and 295/50/15 on 15x10" Eagle alloys! |
#28 |
here's one....4,6 is what belltech said.it came out lower.(thats a good thing.)it's c notched and flipped in the rear.and 3 inch drop spindles,with 1 inch coils.
" Never look up a dead dogs butt." ![]() |
#29 |
I don't recall how many I had to begin with but I pulled out the big thick one on the bottom and I think the next one above that. I remember the leaf pack being really thick and it rode like a 1 ton. Just have 3 left now. I think if you pull the thick one on the bottom and the next one it should give you a couple of inch drop. I don't tow anything or haul anything heavy otherwise it might be a problem since you are taking away tongue weight capacity and also cargo weight capacity. It seems to ride like a half ton should now. Hope this helps. Trial and error is how I approached it. I had more time than money. It gets tiresome going back and forth so hopefully that will give you the desired drop. I also used 2 inch drop shackles and had to notch the bed supports for this so if you plan to use the drop shackles you might want to notch those bed supports while you are at it and everything is more out of the way. I didn't do that while I had things out of the way and it made getting my grinder up in there a little more difficult and not as "pretty".
#30 |
Insert Witty Text Here
That's a really nice truck, 79chevylover. You are sort of local, too.
![]() Slonaker |
#31 |
i don't remember the details, but it was low...5/8, maybe 6/8ish?
#32 |
2"Spindles 2" shackles with all 5 rear leaves
8 x 10 american racing wheels 245/60 15s front 275/60 15s rear I am pretty sure the blazers had the same rear springs as the pickups Last edited by longhorn71; 10-06-2007 at 12:33 AM. |
#33 |
big peice of crap
![]() Code:
#34 |
Hey boatpuller wat size id rms and tires?
#35 |
seventeen's...............225/55/ in front..........275/55 in back.
#36 |
Here's a photoshop of my truck:
Kurt Instagram: @kurtkphoto 1978 C10 Silverado 1991 Camaro B4C |
#37 |
nice rim combo boatpuller i love the fat rears.
#38 |
KMK454 wat drop is ur photoshopped pic supposed to be? nice work on that by the way.
#39 |
Gettinlow & Goinfast
what beautiful ride. post up more pics of your truck!
Protouring Texas built rides- 78' K5 bodied on 22's, 5.3/ 4L60E- sold-Bdydrptk5- http://67-72chevytrucks.com/vboard/s...d.php?t=358390 71' Chevelle #Bigbootyjudy 6.0 LSx, LS9 heads, Magnuson, T56 - http://ls1tech.com/forums/conversion...e-ly6-t56.html 70' Chevelle #EvilAnnie Lsx/4L80/S475 turbo- 85' C20 crew, 5.3/6L90/S475 turbo- 68' C10 5.3/4L60/Level 2 coil overs Facebook- Protouringtexasdotcom Instagram- @Protouringtexas |
