Old 08-09-2007, 02:21 AM   #1
mexgrhd68
mexgrhd68's Avatar
channeling front A-frame section
Just wondering how hard is it to channel the front a-frame section of these trucks. Want to lower it without using any spindles or cut coils to keep that factory ride, just wondering though, since I can't afford the porterbuilt front end . some pictures would be very helpful.
68 c-10 1/2 ton swb fleetside, 79 GMC Sierra Grande 1/2 ton swb fleetside, 99 Dodge Durango 4x4(wifes ride),53 and 55 chevy trucks(dads trucks )
54 caddy 62 series 4 door(younger sons ride, aka 54caddy )
70 caddy 2 door, 89 chevy silverado stepside(older sons rides )
mexgrhd68 is offline   Reply With Quote
Old 08-09-2007, 06:06 AM   #2
68C15
blood type; Retumbo
68C15's Avatar
Re: channeling front A-frame section
if you are referring to moving the crossmember up into the frame there was a lengthy thread here a few years ago. something like X-member drop or something.
68C15 is offline   Reply With Quote
Old 08-10-2007, 01:08 AM   #3
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Dunno if this is what you're thinking, but here ya go
http://67-72chevytrucks.com/vboard/s...d.php?t=251067
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 08-10-2007, 11:02 AM   #4
raggedjim
raggedjim's Avatar
http://67-72chevytrucks.com/vboard/s...ad.php?t=60649
Here's a great thread... the most replied to thread on the Suspension board...
Rg
Rg
raggedjim is offline   Reply With Quote
Old 08-10-2007, 11:30 AM   #5
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Sectioning the cross member will get you 1.25-1.50 inches, depending on how much grinding you want to do. It's a pretty easy task as long as you can cut and weld. You can also "Z" the frame to pick up a few more inches but in doing so you create a wealth of other interference problems to correct. It's a pretty involved process. If you swap in a disc front end you can use drop spindles for 2.5-3 inches (depending on what year front end you use) and still keep the factory ride.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 08-10-2007, 04:40 PM   #6
mexgrhd68
mexgrhd68's Avatar
Rg
Rg
thanks for the thread, but DAMN that was alot of reading, and I just skimmed through it!!!
Old 08-10-2007, 04:59 PM   #7
raggedjim
raggedjim's Avatar
Lot's of info there, for sure.
Rg
Old 08-11-2007, 02:51 AM   #8
mexgrhd68
mexgrhd68's Avatar
Rg
