08-08-2007, 07:50 AM | #1 |
250/overdrive/what gears?
I want to built a truck for economy.It`ll be a shortbed with a 250-6 and 4L60E or 700r4.I`m wondering what gear ratio I should go with to keep it up in o/d but be as high as possible for mileage.Too high gears around town can dog your mileage.I may go with a manual overdrive which will give more control,but I`d want it to be able to stay in o/d as much as expected going up hills.
has anyone played with this idea or had any actul experience with doing this?My thoughts are the 3.08s are out.Maybe 3.42s,or do I need 3.73s?
08-08-2007, 08:38 AM | #2 |
Son of a gun
Re: 250/overdrive/what gears?
I have been real happy with 3.73's in my trucks set up like you are talking about.
Bill BEATERS ARE NEATER |
08-08-2007, 10:06 AM | #3 |
I'm using my 250 and going to put in a later model 5 speed transmission. Either a T-5 or a NV3500. I'm going to start out with my original 3.73's. I've heard they work pretty well for an overdrive set up.
1978 Chevrolet Silverado 3/4 ton 400 small block. 2000 F-250 Powerstroke 2002 GMC Yukon Denali XL |
08-08-2007, 12:09 PM | #4 |
I have 3.73 with the Tremec TKO 5-speed.
Unless you live in a land of no hills, I think a 3.42 rear would mean that you wouldn't use the OD very much without lugging the motor. |
08-08-2007, 12:31 PM | #5 |
That`s what I`m wondering.These trucks didn`t have 3.42s,right?It`s not that much taller than 3.73.I know that with 4.10s and o/d a truck is very hiway friendly compaired to w/o o/d.So,3.73 would be better and help keep some grunt still.Maybe 3.42s would be good with a 283 or 292.
08-08-2007, 04:04 PM | #6 |
Well, you said you wanted to build it for economy, my Stepside with a 250 l6 in it has 2:72 gears and it runs great. Depends how much freeway driving you do, I have a 45 min commute to work, so I wanted to maximize as much as I could with what I had. I wish I could drop a 4 speed in!
_______________ Thomas '78 Silverado '74 Monte Carlo '47 Teardrop Trailer East Texas Classics Local Club |
08-08-2007, 06:19 PM | #7 |
its all about the +6 inches
Tim, I'd go with the 3.73 personally.
there were no 3.42s in these trucks. |
08-08-2007, 06:32 PM | #8 | |
08-08-2007, 06:35 PM | #9 |
If it helps you any special, I turn 2500 RPM's at 70 MPH with my 700R4 with 3.73's and 275/60/15's.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html Last edited by powell72; 08-08-2007 at 06:35 PM. |
08-08-2007, 06:41 PM | #10 |
Yeah,that helps...thanks.
08-08-2007, 07:06 PM | #11 |
Official Site Guitar Shredder
id run good ole 4.56s lol . forget the gas milage
08-08-2007, 07:21 PM | #12 |
and in all reality, you can do 2500 RPM at 65 with 3.07 gears, and spend a WHOLE lot less money.
08-08-2007, 09:21 PM | #13 |
Yeah,I bet a 250/4speed(like M-21s etc)/3.08s would bean economical combo.I`d want a 4spd for starting off and better range.
08-09-2007, 02:35 PM | #14 |
I have a new 400 behind the 250. People usually think that's crazy, but the 400 has taller 1st and 2nd gears so it helps acceleration not robs it, and when it reaches 1=1 in 3rd gear, the highway gears helps bring the RPMS down there.
I just had the tranny rebuilt when I had the V8 in it, so I can't justify to myself pulling it out right now when I have so much other to do later on I plan on a 200 R4 (built right) for an easy swap.
08-09-2007, 04:57 PM | #15 |
i think a 250, nv4500 & 3.73 gears would be the nuts for towing in city and highway driveing myself. i know my 250 with a 3 speed & stock 235r15 tires dont like highway speeds of over 65 mph. also it could use a lower 1st gear when loaded too for takeoff and loaded reverse also.
bob
I BELIEVE IN JOHN 3:16 |
08-10-2007, 06:15 AM | #16 |
Yeah,I don`t want that high geared roll-off from a 3spd.I prolly will try to find a New Venture trans.
08-10-2007, 07:25 PM | #17 |
Out of the carpool lane.
Andy, I tried this once and although it worked- it wasn't ideal. The problem was that with that gearing, I had to use more clutch in 1st gear and it had a slow take off as a result. It'll work for a guy on a budget, but I didn't like it.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... Last edited by Brad; 08-10-2007 at 07:26 PM. |
08-10-2007, 07:30 PM | #18 |
If you run the 700r4 run 3.08 gears due to the low first gear in the 700 its like having a th350 with 3.73, or run 3.42 dont worry if they didn't originally come in that truck neither did the tranny your gonna put in.
1968 Short Fleet 350/700r4 http://67-72chevytrucks.com/vboard/s...d.php?t=249435 1997 Bagged XtdCab Vortec350/4L60e http://67-72chevytrucks.com/vboard/s...44#post2286144 1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver" 1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap |
08-10-2007, 09:52 PM | #19 |
I`m not worried about the 3.42s being non-original.I think 3.08s will be too high,I know 3.73 would do(w/any trans),and I wonder if 3.42s would do since they are between those other two.If they aren`t too high,that`s what I hoped to use.I even have a 3.42 posi.
